Carling rocker switches >
Old 07-08-2025 | 03:10 PM
Default Carling rocker switches
Anybody have white carling rocker switches that still work but aren’t using them. Redid your dash but kept the old switches. Have some switches going bad on my 88 bullet and looking to replace the switches. Not redo the whole dash yet. Thanks for the help.
George
Prowler26 is offline
Old 07-08-2025 | 04:52 PM
George
Do you need the entire switch or just the covers?
Baja 252 Islander
bajaman is offline
Old 07-09-2025 | 12:14 AM
Post a pic of what you're looking for. I have all the switches from a '94 TG.
Griff is offline
Old 07-09-2025 | 07:42 AM
[img alt="These are the rocker switches. Some have the illumination and others don’t. Some are on off on, on off.
If you want to talk on the phone, I’m happy to do this. My number is 240-674-2537. Or send me your number and I will call you. Thank you. "]https://cimg9.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1379/img_2974_c44287943e2491b15d617c6c74d2ca9716251bdf. jpeg[/img]
These are the rocker switches. Some have the illumination and others don’t. Some are on off on, on off. If you want to talk on the phone, I’m happy to do this. My number is 240-674-2537. Or send me your number and I will call you. Thank you.
Old 07-09-2025 | 07:44 AM
Old 07-09-2025 | 08:19 AM
I think these are LTIG series. I did some research while updating my dash on my Bullet, and found some of the switches I needed with black base, black rocker cover. The cover just snaps off/on and the snap in base can be changed as well. Changing the base with lights is a little tricky, but not too bad. Some of them are hard to find white base and white rocker cover. Every place I called wanted me to buy a 100 of them.
I wasn't able to find everything I needed because I wanted double throw with separate illumination, so I replaced them all with the newer Contura series. They are slightly larger cutout and I had to use a flat file to open the hole up a bit. I liked the LTIG better, but it wasn't worth the trouble to find what I wanted.
I have some of the old ones and one or two new LTIG I bought laying around. Let me know what you need.
Old switches
New Switches
Shah Mat is offline
Old 07-09-2025 | 09:55 AM
I have purchased switch covers from New Wire Marine. Good service and products.
https://newwiremarine.com/marine-gra...switch-covers/
Padraig
Padraig is offline
Old 07-09-2025 | 12:20 PM
Thanks guys. Your dash looks good. I have looked at switching to the other style but all switches have gone bad. Trying to see if anybody has some lying around that they aren’t using anymore before I start switching out one by one. I know how I am with parts that still work. Haha
Old 07-09-2025 | 03:17 PM
I have a bunch of them
Griff is offline
Old 07-09-2025 | 07:07 PM
Default !
if he don’t want them I would probably be interested in some or all of what you have man!
87CigCafe is offline
