Close call yesterday!!
We were out in the Velocity cruising about 75 and she started to lay down, quick glance at the gauges and everything looked fine. Looked again and saw fuel pressure dropping.
Slowed down and could smell fuel. stopped and opened hatch to see 3 gallons of fuel in the bilge!!
Quick look and found that an AN fuel fitting broke off the fuel head!!
I am still sick to my stomach thinking about what could of happened to us if she would of lit on fire.
I have been doing fuel lines for 35 years and i have NEVER seen this happen before. It was a sniper fitting.
I happen to have a manual bilge pump to get the fuel out and a towel to clean the rest.
I was able to get the broken fitting out of the fuel head and move some things around to get fuel hooked up again and got to the dock safe.
SCARY!!
SCARY!!
It is the factory murcury mechanical lift pump on a sci 575. I ran a An fitting from fuel pump up to the factory fuel head. The factory line was very restrictive. It was just a short 12 inch hose with a 90 degree on each end. Low pressure 8 psi. The straight fitting 1/4 pipe to -8 an is what broke off. It was not under stress or rubbing on anything. Just crazy strange. Must of been vibration or it was just a bad fitting.
Harmonics due to vibration can be destructive. Prev owner of my Fountain said he was breaking alternator brackets left and right for no apparent reason. He added a stiff spring to each bracket to break-up the harmonics and never broke another bracket again. He also had a rigid 1-piece fuel feed line for the Holley double pumpers crack soon after installing it. It's now a 2-piece feed line assy and 10+ years old.
Dash mounted fuel press gauges are a good thing. Been thinking abt adding an instrument pod for fuel press and wide-band O2 gauges.
I have 2 brushless bilge fans that move a ton of air.
maybe that was just enough to help keep fumes down. Solid tight electrical connections and good plug wires.
Makes you realize how important this stuff is. I run with fans on all the time to help move air through the engine bay.
