2005 275 496 Mag water impeller replace >
Old 08-09-2025 | 02:15 PM
Default 2005 275 496 Mag water impeller replace
Hello all
Anyone tackled the raw water pump impeller replacement? From my initial observation, the bulkhead in from of the motor doesn't leave much room to access. I see both the inlet and outlet ports on the back. The red inlet hose has a quick connector but the outet doesn't. I also see the fuel cooler box to the left of the pump that needs to be set to the side.
Anyone have their experience doing this job and any tips?
TEXASRPM is offline
Old 08-09-2025 | 09:20 PM
bencini231's Avatar
Originally Posted by TEXASRPM
Hello all
Remove the bracket with the pump attached and this will make the whole job much easier.
bencini231 is offline
