1990 warlock 23 world class >
Old 08-12-2025 | 12:27 AM
Default 1990 warlock 23 world class
Does anyone have an idea of what size prop I should try on this boat it’s got a 540bbc 650ish hp. I have read these hull’s love 4 blade props. It came with a 25p 3 blade. Just like to know where I should start for a 4 blade.
mserene02 is offline
Old 08-12-2025 | 04:37 PM
GPM
What RPM are you pulling with the 25
GPM is offline
Old 08-12-2025 | 06:48 PM
not exactly sure have not gotten the boat in the water yet motor should be fired up this week after the carb gets rebuilt. I’m just trying to get an idea with other people that have had this hull with this power have used
Old 08-12-2025 | 09:52 PM
I would start with a b1 28" and see where you are at, but before that just run the 25" to see what you are spinning
CheckmateScarab is offline
Old 08-12-2025 | 10:17 PM
GPM
Props can get expensive, a base line would help, what gear ratio is the outdrive ? What RPM is the peak HP ?
GPM is offline
