Bad Bravo XR! Repair? Replace? Used? >
Old 09-06-2025 | 09:40 AM
Default Bad Bravo XR! Repair? Replace? Used?
My Bravo XR with IMCO -2 lower has some issues. I could hear rattling under the drive shower cap when I leaned over the sundeck with the engine running. Found metal chunks on both drain plugs and black oil with 25 hours on the oil. I took it to a friend and he removed the top ... he said gears are done. Those are about $3k a set. Is there any source for good prices on gears? I have two plus months left on this season. I go out 2-3 time per week. I don't want to spend $20k on a new SC upper and lower or Teague Platinum. I just spent $$ on rebuilding my engine this winter. I'm looking at options while mine gets rebuilt. I could buy a rebuilt Bravo XR with black Merc lower for about $9k. There's a few options here on OSO classifieds. I could buy a used one but who really knows the condition. After mine is rebuilt I would have to install it and I would have to sell the used one. I found some rebuilt uppers on Markeplace for about $5k. But I don't know the condition of my lower at this point. Suggestions?
Delta_Dave is offline
Old 09-06-2025 | 09:48 AM
Mbam's Avatar
Offshoreonly Advertiser
Whatever you do don't even think about replacing the upper without going through the lower. It needs more than a flush.
Mbam is offline
Old 09-06-2025 | 12:44 PM
Yep. It's likely the lower has some damage.
Old 09-06-2025 | 01:06 PM
F-2 Speedy's Avatar
Call the bravo shop see what they have
F-2 Speedy is offline
Old 09-06-2025 | 07:59 PM
Mbam had new xr uppers for sale recently
underpsi68 is offline
Old 09-07-2025 | 06:43 AM
Teague and IMCO SC’s use XR gears, you’ll be no better off
Im guessing the gear look like this?
Pits
Pits
JaayTeee is offline
Old 09-07-2025 | 06:50 AM
How much power?
some people will go to the X( helical ) gears….there’s always the SCX upper
XR gears are prone to this, if it did the other thing that happens less frequently,
you would be buying a new upper
JaayTeee is offline
Old 09-07-2025 | 08:56 AM
I haven't seen the gears. I only have about 625hp, but this drive could have 500-600 hours. It's a 27 Eliminator Daytona. I don't abuse it or hammer it planing, but I run a Max 5. I've heard some guys run XZ upper gears.
Old 09-07-2025 | 04:06 PM
There are some that will run cryno XZ gears, at least they do not pit.
its that or SCX, the XR gears surface pitting sucks and will do it behind a 525.
Wildman_grafix is offline
Old 09-08-2025 | 01:42 PM
XZ gears will also help you pick up a few HP and be much quieter
CheckmateScarab is offline
