TRS Parts
Old 09-07-2025 | 10:51 AM
Default TRS Parts
LOTS OF TRS PARTS
I’m not interested in selling these parts individually. The small parts are too numerous to list individually but you can get a pretty good idea from the photos. $2000.00 plus shipping for everything. Will consider driving a couple of hours to meet someone half-way from Moneta, Va.
1 Upper TRS Gearcase, used, empty, in good condition
1 Lower gearcase with vertical drive shaft installed. No prop shaft, pinion gear is broken.
1 Complete drive unit with all internals except for input shaft. Working with no issues at time of removal.
2 Outer transom plates with gimbals and bell housings. Good condition, no cracks or damage, no issuers when removed.
2 Inner Transom plates, good condition.
NEW
(1) 31-62799A Upper BEARING SET for DRIVE GEAR
(1) 8M0103475 BEARING ASSEMBLY Tapered Roller PINION GEAR
(1) 4362879 upper Pinion GEAR Driven DRIVE SHAFT (32 TEETH)
(1) 4362878 Upper pinion GEAR drive (24 TEETH)
(1) 75832a3 Sierra U-joint
USED
1 LH and 1 RH Propshaft, (light scoring at seal surface)
1 Upper Pinion gear Shaft
2 bearing carriers
1 oil slinger
2 upper front case caps
3 upper input shafts
1 lower pinion gear (undamaged)
MISC SMALL PARTS (almost all are new and most have multiple copies):
Seals, gaskets, hydraulic hoses and fittings, 3 85054A5 Gimbal Housing hydraulic hose connectors and gaskets, hydraulic hoses (used), bushings, hinge pins, Trim ram internal parts,
ctuck0659 is offline
