TRS LH drive, transom assembly, merc trans
Pretty clean LH trs, removed from a functioning boat, lower skeg has a chunk missing fron leading edge but it did not effect operation. Fresh water use. Asking 1200 obo. Also have super clean transom assembly with trim rams, 500.00 and a working merc trans with good drive plate, 500.00. Located in New Jersey if you want everything, 1800. Only reason for removing is to put a bravo on it.
