Hynautiq Oildyne trim tab pump
My trim tab pump quit working, this boat has this old Hynautic trim tab setup.
Where can I purchase a replacement pump asap? Id like to get the boat on the water this weekend
Looks like any power trim / jack plate / trim tab / tunnel tab pump.
Unless there is something special about how much (or little) it flows, so that your tabs move at least at reasonably similar speeds, you should just be able to pick up an Oildyne style trim pump from a local dealer, eBay or someone like Teague or CP.
Green down (like the green grass - I guess a brownish yellow would be more appropriate in SoCal)
Blue up (like the sky)
Black ground
Now, the big debate is whether motor oil or hydraulic fluid should go in the reservoir...
Black ground
On tabs the green (low pressure) / Blue (high pressure are reversed. Very confusing! Blue = down, Green = up.
As Markus says check the relays.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Hardin seems to do blue up, green down like trim.
https://www.hardin-marine.com/instructions/137-8091.pdf
Thanks!
Good to know. Thought the pressure was the same on both ports of the pump.
With my single K-plane used as tunnel tab, it does not matter, but I am now curious enough to check how it is wired...
Hopefully I can pick one up before the weekend. Thanks!
