Donzi 33zx part out
-Stainless louvered side vents 34x5.75: $150 pair
-Through hull water jacketed tailpipes for a transmission setup, with the outer pipes angled inward so as to place them closer to the centerline. These can be setup as dry to the tip, the boat I took them out of had them setup as wet exhaust. The outer jacket of these is 4.5” in diameter. Someone spent a lot of $$$ having these custom made. These will clean up nice I just haven’t had time. $1000 for both sets.
-Ritchie fluid filled compass: $50
-Velvet drive 72c transmissions: $800 each
-perko 493 series sea strainers with elbows and seackcoks: 200 each
-marine vhf with 3’ antenna: $125
-kiekhaefer drive indicators: $125
-2 indoor/johnson marine crank mounted water pumps: $100 each
-blower: $50
-momo steering wheel: $75
-Kiekhaefer Aeromarine twin throttle/shifters, handles are in good shape, crisp action, needs top plate repainted or powder coated: $475
-Sae J1171 marine trim and tilt pumps: $100 each
-Cockpit cover for donzi 33zx, has a few small tears which can be stitched up, would make a good backup $100
-Stainless steel Danforth style anchor, 15 lbs $300
-2 aluminum group 31 battery holders: $50
-2 indoor/johnson marine crank mounted water pumps: $200 for both
Located in Md, local pickup or you pay the ride
-blower: $50
