Mercruiser 496 MAG HO Fuel Injectors >
Old 11-03-2025 | 01:18 PM
Default Mercruiser 496 MAG HO Fuel Injectors
good day, I would like to buy new fuel injectors from Delphi (OEM). BMotorsports and Herko.com offer the ones with 44 lb/hour (460 cc/min) and a coil resistance of 12, on the other hand there is FiveOMotorsports and others who offer the same OEM number with a 12,5 Ohm resistance and lasst there is Summit, that offer th esame number with 42lb/Hr (440cc/min.
My original ones have all a resistance of 12 and the OEM number is 25348180.
Has anybody an idea what would be best to buy?
thx a lot
Marc
fenchem is offline
Old 11-03-2025 | 11:52 PM
Why not just have your injectors cleaned and flow tested??
Griff is offline
Old 11-04-2025 | 03:03 AM
I just thought for round about 100 USD a new setup would be better after 18 years. Cleaning and teting would be also 40 USD each
fenchem is offline
Old 11-04-2025 | 05:20 AM
I would clean the old ones. It should be $200ish to do 8.
The new ones are a crap shoot and most likely flow different than the stock ones which will affect your tune. Most of the time in a bad way.
underpsi68 is offline
Old 11-04-2025 | 04:48 PM
Clean the old injectors. For the prices listed for those new Chicom injectors, they should give you.a free hand grenade.
Ryan00TJ is offline
Old 11-04-2025 | 05:46 PM
thx a lot
Marc
Marc,
I have a set of recently tested/verified OEM injectors I could be talked out of. I had an engine failure and, initially thinking the injectors might have been the cause, I sent them to Smitty (ArcticFriends here on OSO). He flowed them and they tested perfect.
Thanks. Brad.
Brad Christy is offline
