2019 MYCO 37'-39' 21K GVWR Trailer for sale >
Old 11-05-2025 | 05:04 PM
Default 2019 MYCO 37'-39' 21K GVWR Trailer for sale
2019 Myco Trailers MWA37-39XHTR triple-axle boat trailer with 6,000lb torsion axles and LT tires. Bunks configurable/swappable for multiple boat profiles, don't ask if it will fit your boat, configuration/adaptation will be the responsibility of the buyer. Per sticker specs trailer is actually 18K GVWR but it all parts for the axles were 7K P/Ns and the tires are rated for 21K. Specs updated below:
Per MYCO this trailer was originally built for a 2019 Fountain 38CC with quad engines having the following specifications:
- Length: 38'4"
- Beam: 10'6"
- Dry Weight: Approximately 15,600 lbs
- Deadrise: 20.75 degrees
- Hull: Fiberglass / GRP
IF THE AD IS UP IT'S AVAILABLE, $15,000 OR BEST OFFER, will not hold, first cash takes it.
Pickup in Groveland or arrange transport (e.g. uShip)
Freshly refurbished with NEW Bunks, brackets and hardware, NEW Brakes and NEW Wheels. Commonly utilized for boats from 35' to 42' LOA. Few trailers compare to the 10" Beam all-Aluminum construction!
Boats pictured are examples on this model trailer and commonly include: Mystic, Velocity, Formula, Nor-Tech, Invincible, Fountain, Midnight Express, Cigarette, McClain, ShoreStation, Manning
SPECIFICATIONS:
  • Model MWA37-39XHTR
  • Boat Length 37'-39'
  • Carrying Cap 15,400#
  • Empty Wt 2,600#
  • GVWR 18,000#
  • Tire Size LT235/85R16 LR-G 14-Ply LT Tires
  • Tire Capacity 3,750#
  • Tire Pressure 110 PSI
  • Axles 6,000 lb 8-lug
  • Winch 3,500 lb
  • Coupler 2-5/16”
  • Electrical 7-pin round
Last edited by dwasill; 11-06-2025 at 04:15 PM. Reason: Spec correction and original configuration
dwasill is offline
Old 01-18-2026 | 04:58 PM
I may have interest in this trailer. How can I get your number? I can’t get PMs b/c I didn’t re-up my membership.
frickstyle is offline
Old 01-18-2026 | 10:55 PM
You don't need a paid membership to send/receive PM's. As a Registered Member, you can have up to (I think) 100 PM's stored at one time. It used to be only 10. That 100 includes sent and received PM's, so you may need to delete some old ones if you have more than that saved.
Griff is offline
