The basics of setting up a Holley and MSD system >
Old 11-06-2025 | 02:28 PM
Default The basics of setting up a Holley and MSD system
My friend has a 540 with a Procharger, Holley ECU and MSD ignition.
ECU: Dominator / HP EFI V2
Ignition control unit: 6A-L (has a 6M-2 as well)
Distributor: 8560
Cap: 8565
Rotor: 8467
Coil: 8253
What are the basics of hooking these things up to get spark and fuel?
Markus is offline
Old 11-06-2025 | 07:49 PM
Rookie's Avatar
Start at page 30 of the instructions and choose your closest combination. Probably page 32
https://documents.holley.com/89821a0...aa700b52a0.pdf
Rookie is offline
Old 11-07-2025 | 01:26 AM
Default Thank you
Thank you
Seems crystal clear to me.
Markus is offline
Old 11-07-2025 | 02:05 AM
I probably need to dive into that engine bay myself...
Markus is offline
Old 11-07-2025 | 07:17 PM
Rookie's Avatar
If V2 is regarding his software release, I would update that. I'm currently running V5. I don't see a reason for me to upgrade to V6 in marine trim.
Rookie is offline
Old 11-08-2025 | 02:14 AM
He doesn’t even know that, but the boat came with a Holley CD, so we can assume that it is ancient.
Markus is offline
Old 11-23-2025 | 01:10 AM
Distributor: 8560
Cap: 8565
Rotor: 8467
Coil: 8253
Sits fuel injected?
boattrubador is offline
Old 11-23-2025 | 01:49 AM
Default Sits?
Sits?
Markus is offline
