Drive Sync Race Editon >
Old 12-17-2025 | 10:15 PM
Default Drive Sync Race Editon
Have a freshly updated and wired for twin engines MDC - Drive Sync Race Edition with multiple presets. Was custom built for our layout some years back, and includes NMEA2000 output to send Drive and Tab height to the MFD's.
Works great. Just been setting on my desk for a couple years since last update.
$1000 OBO Shipped.
kidturbo is offline
Old 12-19-2025 | 01:51 PM
Is it the 2 or 4 preset version?
What are MFDs?
Does it plug in line with your trim switches?
Older Fountain, trying figure out if I wpuld need additional equipment to make work.
Thank you
areyouliving is offline
Old 12-19-2025 | 03:06 PM
According to my throttle button, it's the 2 preset.
MFD is multi function displays like Garmin. This one has a NMEA 2000 converter option added that displays your drives and tab levels on any modern display.
If switching from cable indicators only, you'll need the merc sensors for both drives, and likely some cable to digital converters to see the tabs settings on screen. The network output data is handled by a separate internal converter that reads range from the same 0-5v sensors as they Sync unit.
It wires directly in at the pump relays, reads positions off your last drive movement, then brings lowest drive up to match the highest when you let off the buttons.
I never got the drives or props dialed in to a point to pick the best presets. But was good enough at keeping them even in default mode.
kidturbo is offline
Old 01-06-2026 | 08:14 PM
Bump for any offers before list it on ebay.
kidturbo is offline
