Is it possible to change the pitch of >
Old 12-11-2002 | 10:54 AM
CelticPride
Default Is it possible to change the pitch of
a particular prop by more than a coupl of inches? I had good results using a Mercury Rev-4 Prop on a FOrmula 242 tha I used to have. It performed better than the Bravo 1. Now I am curious how it would work on my Sonic 31. Problem is I currently have 26p Bravo 1's and the Rev-4 is only available up to 23p
Old 12-11-2002 | 12:07 PM
SeaRay Jim's Avatar
My understanding is that you can only add enough cup to get an effective "pitch" increase of 1" to 1 1/2". I'm no expert so I could be wrong.
SeaRay Jim is offline
Old 12-11-2002 | 03:06 PM
HyperBaja's Avatar
go to the baja forum and ask huston prop.
HyperBaja is offline
Old 12-11-2002 | 06:17 PM
HOUSTONPROP's Avatar
Default changing the pitch?
the pitch can be changed on a stainless prop up or dn 2" and then you can add cupping which will also drop the rpm and give a little more forward travel.changing the pitch any more than that will cause blade distoration and it will not perform like it should. hope I have helped .
HOUSTONPROP is offline
Yamaha 225
Prop Talk
10
10-08-2008 05:43 PM
Powerquest_Baby!!
Prop Talk
6
12-06-2006 06:48 PM
Led Sled
5
01-08-2005 12:48 AM
powerguy
16
08-16-2004 08:24 PM
Elite Marine
2
06-21-2003 11:04 PM
