Konrad 540 HP drives >
Old 12-27-2025 | 10:39 AM
Default Konrad 540 HP drives
This is a pair of Konrad 540 HP, TRS drive conversion package. Left and right with 1.51 ratio and gimbals. Have less then 50 hours of use. $15,000 for everything I do have another drive with short output shaft for staggered set up and drive line transmission.
dewayne6243 is offline
Old 01-25-2026 | 09:08 AM
Bump
Old 03-24-2026 | 08:01 AM
bump
Old 05-03-2026 | 10:57 AM
Bump
Old 05-08-2026 | 12:09 AM
Default Konrad parts
What else will be needed to replace my TRS drives with these units?
schiada.cat is offline
Old 05-08-2026 | 12:25 AM
Default Prop spline size
Do these drives have the same prop splines as the TRS drive?
Old 05-10-2026 | 07:51 AM
Nothing, this is a direct bolt on for TRS set up.
Old 05-10-2026 | 07:52 AM
Yes, same splines.
Old 05-10-2026 | 07:53 AM
Nothing, this is a direct bolt on for TRS set up. Same splines are TRS.
