bmax 2 inch lower gearcase interchangeable with 2 inch imco bravo one shortie >
Old 01-08-2026 | 05:04 PM
Default bmax 2 inch lower gearcase interchangeable with 2 inch imco bravo one shortie
I have a bmax with a 2 in shortie bravo shop late style lower gearcase and i need to know if it will fit on a standard bravo one lower unit if u change the upper drive shaft to bravo one shaft?
Also will a new imco 2 inch lower bravo one style gear case work on a late style bmax if you put the bmax upper driveshaft in it. Im thinking no reason they wouldnt but would the water passages match be the same through the lower unit?
I understand the imco lower gear case has the low water pickup being force fed all the way to the sea pump.
The water pickup on an imco just needs to circulate water to the top of the b max to cool the whole drive but do the water pasages match is what i need to know.
badbug3 is offline
Old 04-22-2026 | 01:24 PM
Bravo Shop & IMCO Sc both work fine with a bmax upper. If using a SC need to drill a second feed hole to put water to the upper bearing cap. Easily done.
The bravo shop std and -2 length vertical shafts are bespoke,
Can you use a bravo shop std or -2 lower on a bravo 1.5 upper or xr? Yes but need a Merc or IMCO std or -2 length vertical shaft and requisite coupler.
deathdealer is offline
