Go Back  Offshoreonly.com > Owners Forum > Donzi
1999 Donzi Zfc 35 twin Verado 300's >
Old 01-17-2026 | 12:25 PM
Default 1999 Donzi Zfc 35 twin Verado 300's
I was hoping to talk to some people who were running twin verado 300s on the 35 foot zfc. I had repowered the boat 5 years ago and have been struggling with slippage. The motors have been fully serviced. They are 25 inch shafts mounted at the second bolt hole. I am currently running 19 pitch rev 4 props. I am having to baby the throttle's up to prevent significant slippage. I am getting cruising speeds into the mid 30s with a WOT high 40's to 50. Was hoping to find some people with similar set ups.
japacker is offline
Old 01-17-2026 | 01:52 PM
My 35 CC with a pad bottom runs 57-59 with Suzuki DF300s with a 2.08 gear ratio and mercury eco enertia props, 21.5 I believe. It ran the same speeds with 22 bravos but slipped like crazy and the cruise RPMs were far higher.
I believe ZFCs should run a few ticks faster. Step bottom. Merc 300 verados should be a little stronger too. Try some other props then look into making sure your engines are running right. They go through ignition pencil coils I know. A diagnostic check for cylinder misfire would be smart.
hogie roll is offline
Old 01-17-2026 | 02:19 PM
I will test the coils to make sure they are running correctly.
japacker is offline
Old 01-19-2026 | 08:53 AM
You should be in the 60s top end, cruising mid 40s. The props sound way too small. What is your gear ratio?
VetteLT193 is offline
Old 01-19-2026 | 07:02 PM
Yep forgot to ask what RPM you’re hitting
Old 01-22-2026 | 10:28 AM
We have the 1.85 : 1 gear ratio
japacker is offline
Old 01-22-2026 | 10:30 AM
We are hitting about 6000 - 6100 RPMS. The motors still have a little more however trying to give it more causes the props to slip.
japacker is offline
Old 01-28-2026 | 01:35 AM
You could try lowering motors, or lightening the front of the boat. My boat was able to blow out bravos at max speed and aggressive trim. I couldn’t trim them as high as the bigger diameter Suzuki or Merc eco props.
Being you have a step boat the trim characteristics won’t be identical to mine though.
Old 02-01-2026 | 12:00 PM
Based on the math I'd think 22-24 inch props, Bravo 1 or rev 4
