Cleaning out my shop & garage – everything must go. >
Cleaning out my shop & garage ? everything must go.
Old 02-09-2026 | 08:22 AM
phughes69's Avatar
Default Cleaning out my shop & garage – everything must go.
Cleaning out my shop and garage — all these parts must go.
Prices do not include shipping.
I will ship parts but prefer a prepaid shipping label.
All parts ship from 48080 – St Clair Shores, Michigan.
TEXT ONLY with what you want: (248) 602‑3751 (Google Voice)
TRS / Driveline / Steering
  • TRS inner transom plates – $200 ea
  • Complete TRS inner transom plate + outer housing (no rams) – $500 ea
  • External steering rams – $500 pair- Pending
  • TRS thrust washers w/ spline nut & nyloc – $10- SOLD
  • TRS trim ram braided hoses (pump → rams) – $25 ea
  • TRS trim rams – $100 ea
phughes69 is offline
Old 02-09-2026 | 08:26 AM
phughes69's Avatar
Exhaust / Cooling
  • Gafrig Power Tip 4" silencers w/ pump + 4" slant‑cut tips – $500
  • Mercury Quick & Quiet diverters + air pump (4") – $500
  • Oil cooler w/ PS cooler – $150
  • Power steering cooler – $100
  • 24" stroke hatch actuator – $250
Old 02-09-2026 | 08:28 AM
phughes69's Avatar
Fuel System
  • –6 straight hose end to 110° – $5
  • Q‑Jet 1" phenolic spacer plates – $10 ea
  • Holley 750 1" spacer plate – $10
  • Holley –6 braided fuel line + distribution block OR steel fuel line – $25 ea
Old 02-09-2026 | 08:30 AM
phughes69's Avatar
Ignition / Electrical
  • MSD advance curve kit, distributor cables, vibration isolators, misc parts – $40
  • Champion V4C spark plugs (8) – $10
  • Champion V9YC spark plugs (8) – $10
  • Mercruiser SBC/BBC points‑style distributor w/ cap, rotor, wires & 3‑ohm coil – $50 ea
  • Mercruiser points‑style condensers + points, Mallory rotor – $5
Old 02-09-2026 | 08:33 AM
phughes69's Avatar
Engine / Accessories
  • Velvet Drive bellhousings (single cooler, top‑mount starter) – $250 ea
  • Bronze‑painted steel Chevrolet valve covers – $100 for all 4
  • Mercruiser 330 valve covers – $50 for all 4
  • Merc trans housing (bare) – $100
  • Bar diaphragm freshwater pump – $25
Old 02-09-2026 | 08:35 AM
phughes69's Avatar
Hardware / Misc
  • Perko cupboard catches (set of 4) – $20
  • Bow cleat – $20
  • Bennett trim tabs (12" × 8") w/ rams – $100
  • Boat storage cart cradle (held 38’ offshore) – $600
Old 02-09-2026 | 08:36 AM
phughes69's Avatar
Big Item
  • Midmark Classic Series wet‑ring vacuum system – CV6 – $1500
Old 02-09-2026 | 10:58 PM
The steering rams, I am looking for some Hynautic k5b rams what type do you have there, thanks
496blower is offline
Old 02-10-2026 | 07:47 PM
phughes69's Avatar
Yes they are K5B cylinders. They came off a TRS boat. Abnd the dimensions I measured toninght match what I found on Sea Stars documentation.
Old 02-16-2026 | 04:41 PM
phughes69's Avatar
Boat cradle is sold
