Thru-Hull Fitting for Switchable Mufflers >
Old 03-03-2026 | 12:13 PM
Default Thru-Hull Fitting for Switchable Mufflers
Anyone know where to get the thru-hull part of this fitting? I pm'ed this person (Alwhite00) but he hasn't been active since 2024.
Shah Mat is offline
Old 03-03-2026 | 01:13 PM
Veteran: Navy
might give these guys a call
they make many different set ups
yours looks like an after thought of sorts to comply with some rules
https://corsamarine.com/collections/all
powerboatr is offline
Old 03-05-2026 | 07:11 PM
Rookie's Avatar
I run my quick fitting inside the transom and the just "T" them out the exhaust ring through either one of the 4 screw holes or drill another hole in the ring for the hose to go through. Gives it a cleaner look.
Rookie is offline
