1990 272 SR1 Transom rebuild >
Old 05-05-2026 | 10:15 AM
Default 1990 272 SR1 Transom rebuild
Hey guys, just got a 1990 272 SR1 with a rotten transom. I’m wondering if anyone has done one of these? Looking for some heads up and possibly some pics.
erikv79 is offline
Old 05-05-2026 | 03:45 PM
It is a big job for a DIYer but not impossible depending on your skilset. Engine/drive needs to come out along with everything mounted to the transom. Swim platform too. Go on utube and look up fishbumptv. That guy has a full catalog of videos on what you will need. Good luck. 👍
sonicss42 is offline
Old 05-05-2026 | 09:29 PM
Lots of threads in the Paint, Detailing, Fiberglass section. Here is one of many
Transom replacement on Checkmate 281 - Offshoreonly.com
Griff is offline
Old 05-06-2026 | 05:51 AM
ErikV,
And get ready for scope creep. It's virtually impossible to escape from what I've observed..
Thanks. Brad.
Brad Christy is offline
Old 05-06-2026 | 09:40 PM
First off, thanks! It’s not my first rodeo, I did my cigarette back in the early 2000’s unfortunately it was before smart phones and what knows what happened to those pics. I appreciate the responses, was looking for specifics for this boat. Experiences even. This is my next winter project and sitting until then. I’ll start a thread when I get started. I’m sure I’ll have lots more questions along the way.
erikv79 is offline
Old 05-14-2026 | 10:44 PM
TomZ's Avatar
Formula didn't do the best job sealing them up and the silent thunder is a transom killer. Water gets trapped and leaks past the exhaust as well as the attaching points. And that's just the transom. Water also gets trapped around the gas tank and makes its way to the front and rear bulkheads. The grid around the tank is not glassed (the wood was only used as a form for the fiberglass subfloor) and rots potentially taking out the stringers all the way up into the cabin.
Not to be the harbinger of doom - they're good boats and I loved my 311 - but these things are approaching 40 years old, and unfortunately, Formula cut some corners. Hopefully, it's only the transom.
Good luck.
TomZ is offline
Old 05-22-2026 | 03:37 PM
My 1988 272 had the transom rebuilt in 2000. It was costly but if you plan to kee
p the boat its worth it.
Pat Ousborne is offline
Old 05-22-2026 | 08:21 PM
TomZ knows. Try reaching out to PH1972 here on OSO. Roscoe did his 1998 242SS and he really knows how to do it least painfully and RIGHT, he is very knowledgeable and extremely talented! (and polite).
Good luck.
GLENAMY 242SS is offline
