Aluminum Swim Platforms
Old 12-13-2002 | 05:46 PM
Question Aluminum Swim Platforms
NEED HELP ON FINDING MANUFACTURE OF THESE
JJONES is offline
Old 12-14-2002 | 12:07 AM
KCHOTBOAT's Avatar
Charter Member #737
If you want to save a few bucks and get the same or better then call J. Kruse 573-302-1380 at Lake of the Ozarks. Custom made for your boat and any color you want.
KCHOTBOAT is offline
Old 12-14-2002 | 10:33 AM
Thanks for the info,Ill give these places a call.
JJONES is offline
Old 12-14-2002 | 12:58 PM
Elite Marine's Avatar
Default How much Too Old
How much was the platform? I need one for my 24 Pantera Sport. Same color purple too!!!
Thanks,
Kirk
Elite Marine is offline
Old 12-14-2002 | 01:55 PM
LIOPA's Avatar
Try DANA MARINE - 909-279-5005
Any color and size. They can also coat for salt water use.
LIOPA is offline
Old 12-15-2002 | 05:01 PM
wetpleasure
I made my own swimplatform. ordered the metal and had a friend that was fixing alum. heads weld this for me then grounded the welds then sanded then buffed it out. then had it powdered coated clear.
Old 12-16-2002 | 08:59 AM
Too Old did the platform you bought fit your mistress is that a
baja platform thanks
Bad to the bone is offline
Old 12-16-2002 | 10:05 AM
Sean's Avatar
BBracket is the ONLY place to get swim platforms...Mike Briton builds the best around.!
Sean is offline
Old 12-16-2002 | 10:51 AM
RLW
Sean, did you buy one from Briton? If so , how much and what did you put it on?
RLW is offline
Old 12-16-2002 | 11:03 AM
Sean's Avatar
I bought mine 2 years ago for my old boat from Mike. it was 1200 powder coated and the top was non-slip. It fit perfectly the first time and the welds and construction were top notch! Mike has done platforms for just about every boat out there and knew my transom angle and everything. I had him angle mine up slightly so it was level while in the water. here's a pic
Sean is offline
