520 hp roller motor for sale
Hey guys IM selling my motor 454 fully roller carb to pan only
no accessories 1050 dominator new eagle crank,h-beam rods,
forged pistons,rectangular heads with 1.625 isky springs ported.
built to last only ten hours of breakin time still on the boat.80 pounds of oil pressure over $8500.00 on this motor will sell for
no less than $5000.00. I just baught a 871 Mike Kual blower
to put it on a 604 ci. motor I have.For further questions you
can call me at 305.951.0595 cell or M/F 8 TO 5 AT 305.882.7000
EXT.3201
EXT.3201
All the work was done at Mesa Balancing in Hialeah.The block
was maged bored and honed, line bore and hone.The pistons
are speed pro L2399F30 forged with cat h-beam rods,the crank
is an eagle 4340 steel cut 10/20.Double true roller timming chain
cloyes,aluminum timming cover and gill oil pan,meeling high
volume oil pump.This motor has 70 to 80 pounds of oil pressure
all day long.The heads were ported at the chambers they have
2.25 intake and 1.88 exhaust valves stainless steel with 1.625
isky tool room valve springs with titaneum retainers over $8000
spent in parts and machining.The valve covers on the picture are not included,but i have a set of Teague marine tall valve covers for it.the alternator and bracket the seawater pump,crossover
bell housing, oil cooler and wiring harness is not included.I need them for my big motor. the distributor and wires is included thunderbolt 4 with new cap rotor and hp module.For further answers feel free to call me.thanks Albert
Fast Shafts
0
04-20-2008 11:19 AM
