Raising compression by milling heads >
Old 12-15-2002 | 06:35 PM
blue thunder's Avatar
Default Raising compression by milling heads
How many thousanths milled from the head will it take to reduce one cc in combustion chamber volume? This is on open chamber bbc heads. Looking to raise compression from 8.1:1 to 8.5:1 (at least). Using aluminum edelbrock heads, so I don't think I can use the steel shim gaskets?? Have closed cooling though, so corrosion wouldn't be a problem if I could. Any ideas/input would be appreciated,
BT
blue thunder is offline
Old 12-15-2002 | 07:00 PM
formula31's Avatar
I have a formula around somewhere for angle milling. Ill look for it at work tomorow. It should work for straight cut with a little massaging.
formula31 is offline
Old 12-15-2002 | 07:07 PM
I thought about angle milling too, but afaid that would make my exhaust angle out too much? Any experience there? I have twins and the room between the risers in minimal already.
BT
Old 12-15-2002 | 07:11 PM
Make sure that you mill the intake manifold after the heads are milled. This will make for a trouble free assembly.
Most performance machine shops know how much to mill to change compression.
Gearhead99 is offline
Old 12-15-2002 | 09:38 PM
KAAMA's Avatar
Blue Thunder, I don't think you want to go to all the trouble of ANGLE milling your heads. Yes you will make more power with angle milled heads, but if the shop makes one teensy little mistake (and they may not always admit it by telling you) it will cause you a ton of headaches! Just ask Mr. Gadgets---it's not worth the headaches and all the grief. STRAIGHT milling the heads would be okay---but ANGLE milling you're just asking for potential problems. We wacked off .040" from my heads to gain about a 1/2 point in compression, but understand there are variables involved. Also, do NOT mill anything off the intake manifolds until you FIRST mock them up on the milled heads. We thought we had to mill my intake manifolds after milling .040" off my heads, but found out we didn't have too---they fit fine. Best Wishes.
KAAMA is offline
Old 12-15-2002 | 09:51 PM
formula31's Avatar
Yea , I agree . Having done the angle thing, I wouldnt do it again. It makes everything custom. It didnt really affect my exhaust enough to notice.
Old 12-16-2002 | 09:05 AM
Ratchet's Avatar
Going only a 1/2 pt in compression..........How much will that really give you
Cost + Headace of fitting stuff may not even = noticeable gain ?
Ask some guys who have played around on the dyno what an expected gain will be before you go through the trouble.
Just a thought.
Ratchet is offline
Old 12-16-2002 | 11:48 AM
bobby daniels
HEY GUYS THE RIGHT WAY TO DO IT IS ANGLE MILL THE HEADS SO ANY STOCK INTAKE WILL FIT WITH OUT CUTTING THE INTAKE ,,I DO THIS ALL THE TIME AND IT KEEPS EVERYTHING IN LINE
ONE HALF POINT DOES HELP ON A N/A MOTOR AND FOR THE 40.00 BUCKS TO CUT THE HEADS ITS CHEAP H.P. NOT ALL SHOPS KNOW HOW TO DO THIS BUT MOST GOOD ONES CAN
Old 12-16-2002 | 04:02 PM
I had my 454 rect port heads milled .020. The machine shop that did the work said that for every .005, it would reduce the CC size by 1cc. When I calculated it, it increased comp by .25.
The machine shop also said that as long as you don't go more than .030, that there shouldn't be any problems with the intake.
Also take into consideration which head gaskets you are using and which ones you are going to use. Stock mercs are like .030 and the Fel pro Marines are .039. So if you mill .030 and go from the stock mercs to Fel pro's you gain .021 and about .25 on your CR.
Griff is offline
Old 12-16-2002 | 04:07 PM
Also as far as gaskets with the aluminum heads, the felpro #1037 which I used says its compatible with iron or aluminum heads. The #1027 says aluminum only. The 1037's have a SS core.
Griff is offline
