alt/ps  low mount brackets >
Old 12-19-2002 | 08:13 PM
traviss's Avatar
Default alt/ps low mount brackets
I am trying to move my altenator and powersteering down on the port side of my motor, I know cp performance carries the alt low mount for port side, but I can't find a low mount power steering bracket for port side ( so it is mounted above the altenator). anybody else make these for sbc's?
Thanks boys
Travis
traviss is offline
Old 12-20-2002 | 08:12 AM
Official OSO boat whore
I presume that IMCO doesn't have one? Again, I'd try March performance. They have several combinations of brackets that might help.
Cord is offline
Old 12-20-2002 | 10:44 AM
37outer
Try Keith Eickert Products.
Old 12-20-2002 | 05:38 PM
traviss's Avatar
thanks boys.. IMCO slipped my mind and I found some in the car mags that look pretty tuff too.
Travis
traviss is offline
Old 12-21-2002 | 10:04 PM
Try www.zoops.com They have a low mount alternator bracket that's pretty nice. The getcha is that there is no provision for a ps pump.
Cord is offline
Old 12-22-2002 | 08:12 AM
traviss's Avatar
Thanks cord..
I checked out IMCO and they make both, I might just have to put my ps pump on the starboard side instead of the port side cause IMCO's ps bracket goes on the starboard side. I'll do whatever it takes to get these ugly things off the top of the motor
Travis
traviss is offline
Old 12-22-2002 | 10:39 AM
Pete B's Avatar
Charter Member#203
Veteran: Navy
the imco one mounts on the port side, you will need to then find a tie rod to connect to water pump to put tension on belts.
Pete B is offline
DesertRage
Swap Shop
5
10-13-2008 08:29 PM
RLW
20
03-08-2007 02:22 PM
Panic Button
3
12-28-2004 07:51 AM
US1 Fountain
6
06-03-2004 07:39 PM
NASTY HABIT
14
08-21-2002 10:21 PM
