Bilge Paint
Old 12-22-2002 | 06:31 PM
powerboat
Default Bilge Paint
Hey guys what is the best paint to use in the bilge. I Tried re gel coating in bright white last season and it is too poris. The oil and dirt are hard to clean off. I have looked at Interlux bilgekoat and was wondering about Awlgrip. Any suggestions would be appreciated. Since this will be the second time stripping the engine compartment of any hardware in a year. I wish to do it right this time.
Old 12-22-2002 | 06:33 PM
I did mine in epoxy, cleans up great.
Rich
BOSSMAN is offline
Old 12-22-2002 | 06:38 PM
powerboat
what brand epoxy.
Old 12-22-2002 | 06:44 PM
Elite Marine's Avatar
Default Awl Grip
Awl Grip is extremely durable. Expensive, but worth it. It can be brushed, rollered or sprayed. Most boat builders use it for the bilge area.
Elite Marine is offline
Old 12-22-2002 | 07:02 PM
I used everstar epoxy it cost more and more work but it cleans up great, I was told awl grip was good and easy to work with, I found this out when I had already finished mine.
Rich
BOSSMAN is offline
Old 12-22-2002 | 07:38 PM
Audiofn's Avatar
Charter Member #232
just watch out with Awlgrip. It goes on very thin so if you scratch it with dirt it will go through. Also it is VERY TOXIC!!!!! Do not even open it and mix it with out a GOOD mask.
Jon
Put your best foot forward!
Audiofn is offline
Old 12-22-2002 | 08:15 PM
HyperBaja's Avatar
Rhino Lining
HyperBaja is offline
Old 12-22-2002 | 08:35 PM
Pantera24's Avatar
Try "Easypoxy" from Pettit..awesome stuff and a LOT cheaper than awlgrip and does the job very well. Surface preparation is the key ..make sure it is clean ..no oil, no gas etc. You roller or brush on.
Pantera24 is offline
Old 12-22-2002 | 08:58 PM
puder's Avatar
speel chekk this fokker!
i sprayed on the easypoxy and it worked prettty well. Get a good air mask even if you are going to roll or brush it on.
Pardon me, while I whip this out!
puder is offline
Old 12-22-2002 | 09:01 PM
buck183's Avatar
Originally posted by HyperBaja
Rhino Lining
Hyper,
We don't say that word around me, I'm an Arma Coatings dealer. I can spray circles around that crap.
Buck
#183
buck183 is offline
