Need some help - How high is too high for water pressure? >
Old 12-23-2002 | 07:26 AM
GNJ2
Question Need some help - How high is too high for water pressure?
I have a twin (stock) 1998 502 Mag MPI engine application. One of the engine's water pressure indicates 22psi at 3300rpm and goes up to 27 psi at 5000RPM. The other seems to stay under 20psi from 3K and up. Can someone provide some insight here? How does the cooling system regulate this pressure and is this pressure normal or too high at 27psi?
Old 12-23-2002 | 07:04 PM
SpeedGirl's Avatar
OSO Moderator
They should read the same.. Swap the gauges to make sure you dont have a bad gauge.... If the pressure stays high then look for a restriction...(kinked hose or some sort of bolckage)
You are judged by the company you keep!
SpeedGirl is offline
Old 12-23-2002 | 08:47 PM
Kanookstr's Avatar
32' SUNSATION
Merc says not over 35 psi, But most engine builders on here say between 22-27 psi
Kanookstr is offline
Old 12-24-2002 | 05:33 PM
BLOWN 1100's Avatar
18 lbs is enough, thay way you don' t worry about blowing
a head gasket or hose.
BLOWN 1100 is offline
Old 12-26-2002 | 08:00 AM
GNJ2
OK thanks for the input.
Ran-Dom 32
34
11-27-2008 10:57 PM
D Harry
10
06-19-2007 08:23 PM
chip12345
19
05-22-2005 05:25 AM
jeffg
24
06-18-2003 01:46 AM
Jrock
11
05-25-2003 01:57 PM
