OT.  Fuel filter location 95 Suburban? >
Old 12-23-2002 | 10:48 PM
lrlagmay
Question OT. Fuel filter location 95 Suburban?
(1995 Chevy Suburban 350 non-vortech)
My truck severely bogs when I floor it. I first noticed it when coming over a mountain pass (after filling the tank). It will eventually reach highway speed after really struggling. When I reach a cruising speed, the truck will hesitate and be "jerky". There are no problems in starting the vehicle.
I'm thinking of changing the fuel filter out, but need some direction. Could you let me know how many are there, and their locations. Please give me any info that will make it easy and safe.
Thanks!
Old 12-23-2002 | 11:00 PM
lrlagmay,
There is one filter on your Burb located on the main frame rail on the passenger side near the rear wheel. It is a fairly large canister as far as fuel filters go. Can be a real b**ch to get off if its never been replaced before. Becareful not to twist the fuel line or round off the tubing nuts. A tubing nut wrench is almost mandatory. Hope this helps.
P.S.: You will take a "gas bath" so be ready!!!!
ThirdBird is offline
Old 12-24-2002 | 09:17 AM
Wally's Avatar
Were doomed!
I thought it was on the drivers side.... has been on the other 3 chevys i had (but not suburbans)
Only advice i can give is to pull the relay or fuse for the fuel pump and run the engine...that will take the fuel pressue out of the line and not spray all over you when you open it. Have plenty of rags and a small bucket to catch any gas...
-Wally
Wally is offline
Old 12-24-2002 | 09:21 AM
I think Wally is correct about it being on the drivers side. I also thought it was about in the middle of the truck (front to rear). Good luck.
Shane is offline
Old 12-24-2002 | 09:25 AM
rainmn's Avatar
I had a 95 Yukon, it was on the driver's side on that. I also took a gas bath when I did mine.
rainmn is offline
Old 12-24-2002 | 09:51 AM
Pete B's Avatar
Charter Member#203
Veteran: Navy
should be on the rail.
Pete B is offline
Old 12-25-2002 | 12:10 AM
R Addiction's Avatar
AT Cult Member #3
It is on left frame rail almost directly under drivers seat.
R Addiction is offline
Old 12-25-2002 | 12:16 AM
Mrgoodwrench's Avatar
pimpthis.com
Make sure the O-Rings stay on the fuel lines when removing from the filter.
pimpthis.com
Mrgoodwrench is offline
Old 12-25-2002 | 12:44 AM
Yeah, maybe you guys are right, it might be on the drivers side. Getting old, memory is going south. I would have checked to verify but toooooo much snow, slop, salt to get under there just to check. Plus, I'm just to lazy
In any event, its definitely on the frame rail, you'll find.
Old 12-25-2002 | 09:27 AM
buckknekkid's Avatar
Default hmmmmmm
I'll crawl undermine and look. At least my sts has a big sign on iy hanging under the car so us dummies can find it. Merry Christmas guys
buckknekkid is offline
