Kaama Drive Ujoint Seperation
I AM REPLACING THE OUTDRIVE BOOTS ON MY KAAMA DRIVES AND AM AT THE POINT OFF PULLING IT A PART BUT THE UJOINT IS HOLDING IT TOGETHER. IVE GOT THE PIN OUT,ITS JUST RUSTED TO GETHER,ANY BODY HAVE ANY TRICKS OR IDEAS.THANKS.
Like you said, it should be just one pin in one side of the shaft. I know it's not much help but I would soak it real good with penetrating oil like Liquid Wrench (not WD-40) and tap the shaft/joint lightly with a hammer. Try some heat if that dosn't work. I think I had to hit the case with a RUBBER mallet to get it to start to come apart. BE CAREFUL DO NOT BREAK THE CASE.
Straight bottoms and flat decks
