Pop-Up Gas Caps, Where do you get them???? >
Old 01-01-2003 | 06:49 PM
Sea-Min
Default Pop-Up Gas Caps, Where do you get them????
I have a 38 Donzi, that has the S.S. pop-up gas, water and waste caps. I drpped the fuel cap in the lake last weekend.
Anybody know who makes this cap? I have only seen the commom S.S. that requires the Key.
Clark
Old 01-01-2003 | 07:47 PM
I don't know if it the same cap but Accon makes a pop up fuel fill.
Padraig is offline
Old 01-02-2003 | 10:50 AM
If you are referring to the ones that flip open from one side, Eddie Marine sells them.
They may be smller than the what you want so call EM and check the dimensions before you order.
I ordered a replacement for my older Cig and the hose barb was the correct size but the base and cap were a lot smaller than the one on my boat so I had to do some glasswork to make the hole in the deck smaller.
Hope this helps.
THRILLSEEKER is offline
Old 01-07-2003 | 07:26 PM
liquid asset's Avatar
Livorsi Marine Part# pfgc
liquid asset is offline
Old 01-07-2003 | 08:07 PM
speedrush's Avatar
Where can I get them around Charlotte NC
speedrush is offline
DONZI
07-21-2008 02:11 PM
Shah Mat
10-27-2004 07:39 PM
AugiePensa
OPA/The Jersey Boyz
1
10-07-2004 10:43 PM
Chris288
Baja
3
03-02-2004 09:03 PM
belaire1956
Eliminator
7
10-17-2002 09:53 AM
