porpoising and chine walking.....what cause's it?? >
Old 01-02-2003 | 12:05 PM
Wally's Avatar
Were doomed!
Question porpoising and chine walking.....what cause's it??
this is more directed at people who build boats like Sharky and Steve1 but its open to all comments...
So i was wondering...what causes the two and how can it be avoided....both during and after the boat is built? Is it more of a weight/balance thing? is part of it due to worksmanship on the hull... i.e. hook/rocker in the hull??? Just curious.
-Wally
Wally is offline
Old 01-02-2003 | 12:18 PM
cigarette1's Avatar
Member #2 ....Jeeezz
All kinds of chit .... but most cases are solved through trim
G
cigarette1 is offline
bobby daniels
SOME BOATS AT SPEED START LETTING THE DRIVE OR DRIVES START SWAYING BACK AN FORTH WITCH WILL GET WORSE AND WORSE AS YOU GO FASTER,, WITH OUT HYD. STEERING ,SO AD HYD STEERING AND ALOT OF TIMES IT WILL CORRECT THIS CHINE WALKING
388 'S HUSTLERS DO IT DUE TO TO MUCH LIFT BUILT IN THE HULL TO GET IT TO RUN IN THE 80'S ,,,,,,,A WHILE RIDE AFTER 95 EVEN WITH STEERING
Old 01-02-2003 | 12:44 PM
Wally's Avatar
Were doomed!
Bobby, how can a boat have too much lift? I guess there has to be a compimise but i thought the less wetted surface the better.....to a point ofcourse....
-Wally
Wally is offline
Old 01-02-2003 | 12:48 PM
HyperBaja's Avatar
Look at those hydros. You can see to much lift in them as the back flip over!!
As cig1 said, mostly corrected in trim.
HyperBaja is offline
Old 01-02-2003 | 12:50 PM
PhantomChaos's Avatar
Usually, it's caused by this specific logo on the side, although, just removing the logo doesn't seem to help.
PhantomChaos is offline
Old 01-02-2003 | 12:54 PM
Tbonepmp's Avatar
The Senior Charter Member #1070
Happens alot when people add extension boxes and mess up the CG of the boat... There is a 38' TG at the lake that has boxes and when running above 70mph it porpoises so bad that it will actually start leaving the water on its own... even when the water is like glass..... JBK can vouch for this for he has witnessed it as well....
(What you see, is what you get!)
"Live every day to it's fullest for you give a day of your life to it."
Tbonepmp is offline
Old 01-02-2003 | 01:07 PM
later's Avatar
Hey Tbone that wouldnt happen to be the teal graphic 38 with blower motors is it, every time i see that boat running it is porpoisin real bad.
later
Dave
later is offline
Old 01-02-2003 | 01:08 PM
Tbone,
I think I know who you're talking about.
I have to agree. It's been my experience the hull design, CG, drive height, trim angle, and prop choice can all affect porpoising.
Gary
Gary Anderson is offline
Old 01-02-2003 | 01:10 PM
cigarette1's Avatar
That Gun can be corrected ....
Change X-dim
or
Larger dia props
or
Adj trim
G
