2000 454 Mag question >
Old 01-06-2003 | 06:57 PM
Mack312
Question 2000 454 Mag question
We have two 2000 454 Mags MPH (385 hp).
Do these have roller rockers?
I searched the board and did not find an answer.
Thanks in advance!
Joe
Old 01-06-2003 | 08:21 PM
Elite Marine's Avatar
Default Should have rollers
That engine should have roller rockers...pull a valve cover and see!
Elite Marine is offline
Old 01-06-2003 | 08:42 PM
Mack312
NO!
Only 52 hr on them and no leaks.
Old 01-06-2003 | 08:49 PM
Mack312
Pantera,
You are correct and thanks.
I found a manual I thought was
200 miles north at Lake Eire with the boat.
Thanks again.
Joe
PS Still not pullin those covers, not until I need to.
Old 01-06-2003 | 10:02 PM
blown formula's Avatar
Actually, you can pull the PCV /vent hose out of the valve cover & see if they are rollers or not..... I believe they are roller rockers, but not roller lifters.
blown formula is offline
Old 01-07-2003 | 09:15 AM
I have a 95 454 MAG EFI 385hp and it does not have roller rockers. I added them two seasons ago. I thought the later cool fuel models also did not have roller rockers, but they did have hydraulic roller lifters.
FBRONCO is offline
Old 01-07-2003 | 09:18 AM
rpm
It will have roller lifters, but not roller rockers. They will be stamped non-adjustable from the factory.
Rod
Old 01-07-2003 | 04:11 PM
Vinny P's Avatar
I hate the winter!!
I have a '99 454 magnum. It has stamped steel non-adjustable rockers.
Vinny P is offline
Old 01-07-2003 | 09:27 PM
H2Xmark's Avatar
RPM and Checkmate are right, it has a hyd. roller cam with non adjustable rocker arms, only the 500hp's[and higher] have roller rocker arms, you can add them to that motor with no problem
Mark
H2Xmark is offline
Old 01-07-2003 | 10:25 PM
mcollinstn's Avatar
yeah, what those guys said -
factory style hydraulic roller lifters
factory style stamped steel bolt-down rockers (no rollers anywhere).
mcollinstn is offline
snake plissken
Wanted
5
03-03-2008 09:32 PM
mark30h
5
06-28-2007 09:52 AM
mark30h
1
03-09-2006 07:06 PM
liquid asset
27
07-09-2005 08:00 AM
formula1
7
12-03-2003 07:24 AM
