cam for a 540 >
cam for a 540
cam for a 540
Old 01-07-2003 | 06:22 PM
KCHOTBOAT's Avatar
Charter Member #737
Default cam for a 540
Need to put a larger cam in a 540 and would like to know what size people are running. The motor has merlin heads with 345 intake runners, dart intake and holley 950. The cam I am running now is a comp hyd. roller part number 01-775-8 lift is .591 intake and .601 exhaust. The motor is bolted to a bravo 1. Thanks for any info.
KCHOTBOAT is offline
Old 01-07-2003 | 07:22 PM
Official OSO boat whore
Mine is a crane 741 cam. The current number is HR-306-2s-14 IG. This cam has the following specs: 244i 256e duration, 114 degrees of separation, .632" lift. Your heads and carb suggest that your existing motor is making more than my 600hp, and proably at a higher rpm. If so, then you may consider stepping up to the 751 cam-but you'll be spinning it pretty hard.
Cord is offline
Old 01-07-2003 | 08:48 PM
MIKEHTMSR24's Avatar
Post MY SET-UP
I have the 741 on my 540 also. Full port and polish Eldebrock head with port matched intake. It dynoed out on hp at 683 @ 5680. They didn't take the dyno any higher and torque was 676 @ 4700. Carbed with a Barry Grant 850 flowing 930 cfm. One sweet running motor from 300 rpm to 5600!
MIKEHTMSR24 is offline
Old 01-07-2003 | 09:09 PM
Turbojack's Avatar
Crane 741 here also but I thought it was on 112 not 114
Turbojack is offline
Old 01-07-2003 | 09:13 PM
KAAMA's Avatar
My 540's have Crower hydraulic rollers 236/244* on 114* lobes, fully ported Dart Pro-1 aluminum heads that oringinally started out at 310cc intake runners....with full port (guessing) they are now probably about 320cc. Engines make about 682hp @5500rpm (about 699hp @5700rpm) and 694 foot pounds of torque @4800rpm. My cam is very simular to MIKEHTMSR24'S Crane 741 hyd roller cam as well. You can usually get away with a smaller cam with well ported heads. Typically, I here of some guys running larger 244*/256* cams in a 540" engine which is okay, but I actually prefer running a smaller cam that I can get away with for smooth idling/drivability.
KAAMA is offline
Old 01-08-2003 | 09:36 AM
blown1500
I agree with KAAMA. The heads are critical. I ran a 540 not too long ago with Hendrick Motorsports modified Chevy aluminum heads, 9.0:1 actually measured compression. The cam was a Comp Cams 288AR8. It likes valve springs and is solid roller so it needs attention but it made 724lb-ft at about 5100rpm and 721hp at about 5650 on Hendrick's dyno. Solid is better IF you don't mind adjusting valves and the maintenance!
Old 01-08-2003 | 10:04 AM
KCHOTBOAT's Avatar
Charter Member #737
Thanks for the input. I sold the motor to a friend and he wants something more than the cam I had in the motor.
Old 01-08-2003 | 10:07 AM
bobby daniels
HEY BLOWN 1500 DID YOU EVER GET OFF THE BLACK TAR HERION?? YOU DO THINK BETTER ON IT !!!!!
Old 01-08-2003 | 10:15 AM
KAAMA's Avatar
What is that?-----Chewin' tabaccy???
KAAMA is offline
Old 01-08-2003 | 10:18 AM
bobby daniels
YEAH MARK HE'S BAD WILL P.M. YOU SOON
BOBBY
