Holy Cr@p This Is Cool !!!! >
Old 01-09-2003 | 02:31 PM
glassdave's Avatar
Neno the mind boggler
Default Holy Cr@p This Is Cool !!!!
now THIS is a MOTORCYCLE. . . . wonder when i can put an order in. . . chrysler just unveiled it at the detroit auto show . .
08 OPA High Points Champion
glassdave is offline
Old 01-09-2003 | 02:33 PM
glassdave's Avatar
heres a link to some info
your thomas hawk sir
Old 01-09-2003 | 02:34 PM
Dean Ferry's Avatar
Veteran: Air Force
More data on this beast!
The Dodge Tomahawk Motorcycle ConceptNow we're really reaching...but this thing may actually reach production, according to #2 exec Wolfgang Bernhard, who said we'd know by summer 2003. Yes, it's a Viper V-10 based motorcycle, a 500 horsepower engine sitting out in the elements with some wheels beneath it. The price would be at least $250,000, and there would be only a few hundred made. The Tomahawk can considering whether to build a few hundred at a price of at least $250,000 each.
The Dodge Tomahawk can reach 60 miles an hour in about 2.5 seconds, and has a theoretical top speed of nearly 400 mph. Each pair of wheels is separated by a few inches and each wheel has an independent suspension. Bernhard said four wheels were necessary to handle the power from the engine.
DIMENSIONS:Length: 102 inches
Width: 27.7 inches
Height: 36.9 inches
Wheelbase: 76 inches
Seat Height: 29 inches
Weight: 1,500 lbs.
Track, Front: 8.75 in
Track, Rear: 10 in
Weight Dist: 49F/51R
Ground Clearance: 3 in
Fuel: 3.25 gallons
ELECTRICAL SYSTEM:Alternator: 136-amp high-speed
Battery: Leak-resistant, maintenance-free 600 CCA
Lighting: Headlights consist of 12 five-watt LEDs, front, with beam-modifying optics and masked lenses. Eight LEDs, rear. Headlamps articulate with wheels.
TRANSMISSION: Manual, foot-shifted two-speedAluminum-cased two-speed, sequential racing-style with dog ring, straight-cut gears
Gear Ratios: 1st 18:38; 2nd 23:25
Clutch: Double-disc, dry-plate with organic friction materials, hand lever actuated with assist
Final drive: Dual 110-link motorcycle-style chains
Front Sprockets: 14 teeth
Rear Sprockets: 35 teeth
ENGINEType and Description: 10-cylinder 90-degree V-type, liquid-cooled
Displacement: 505 cubic inches (8277 cc)
Construction: 356-T6 aluminum alloy block with cast-iron liners, aluminum alloy cylinder heads
Bore x Stroke: 4.03 inches x 3.96 inches (102.4 x 100.6)
Valve System: Two pushrod-actuated overhead valves per cylinder
with roller-type hydraulic lifters
Fuel Injection: Sequential, multi-port electronic with individual runners
Compression Ratio: 9.6:1
Power (SAE net): 500 bhp (372 kW) @ 5600 rpm (60.4 bhp/liter)
Torque (SAE net): 525 lb.-ft. (712 Nom) @ 4200 rpm
Max Engine Speed: 6000 rpm
Fuel Requirement: Unleaded premium, 93 octane (R+M/2)
Oil System: Dry Sump
Oil Capacity: 8 qts. Mobil1 10W30 Synthetic
Cooling System: Twin aluminum radiators mounted atop engine intake manifolds, force-fed from front-mounted, belt-driven turbine fan
Coolant Capacity: 11 qts.
Exhaust System: Equal-length tubular stainless steel headers with dual collectors and central rear outlets
BODY/CHASSIS:Layout: Longitudinal, centrally mounted engine, rear-wheel drive
Chassis Construction: Monocoque, engine is central, stressed member
Body Construction: Billet aluminum
SUSPENSION:Front: Outboard, single-sided parallel upper and lower control arms made from polished billet aluminum. Mounted via ball joint to aluminum steering uprights and hubs. Five degrees caster. Single, fully adjustable centrally located coil-over damper (2.25-inch coil with adjustable spring perch); pullrod and rocker-actuated mono linkage. Center-lock racing-style hubs
Rear: Hand-fabricated box-section steel inboard swing arms, incorporating "hydral-link" lockable recirculating hydraulic circuit parking stand. Single fully adjustable centrally located Koni coil-over damper (2.25-inch coil with adjustable spring perch); pushrod and rocker-actuated mono linkage. Center-lock racing-style hubs
STEERING:Type: Dual hub center type.
Steering Linkage: Rocker arm and push/pull rod with roller bearings. Polished billet aluminum steering yoke with turned aluminum grips and billet levers
Steering Lock: 20 degrees, left and right
Lean Angle: 45 degrees, left and right
TIRES and WHEELS (4):Type and Material: Billet aluminum discs, asymmetrical
Size, Front (2): 20x4
Size, Rear (2): 20x5
Tires Mfr. and Model: Dunlop custom-made symmetrical
Size, Front (2): P120/60R-20
Size, Rear (2): P150/50R-20
BRAKES:Front: 20-inch perimeter-mounted drilled machined stainless steel rotors, one per wheel. Two four-piston fixed aluminum calipers per wheel (16 pistons total), custom designed. Blue anodized caliper finish. Hand-activated.
Rear: 20-inch perimeter-mounted drilled cast-iron rotors, one per wheel. One four-piston fixed aluminum caliper per wheel (8 pistons total), custom designed. Blue anodized caliper finish. Foot-activated.
PERFORMANCE:0-60 mph: 2.5 seconds (est.)
Top Speed: 300+ mph (est.)
MD
Dean Ferry is offline
Old 01-09-2003 | 03:03 PM
Uncle Toys
Kind of reminds me of Jessie James on Monstor Garage. Why'd you build it Jessie, "because it was soooo wrong!"
Old 01-09-2003 | 03:09 PM
3.2 gal fuel capacity for a V10 wont get you too far.
Gary
Gary Anderson is offline
Old 01-09-2003 | 03:18 PM
Sydwayz's Avatar
Forum Regulator
I'll take two please.
Sydwayz is offline
Old 01-09-2003 | 03:42 PM
SpectreBoy's Avatar
Default bout dean
Dean likes to type doesn't he?
SpectreBoy is offline
Old 01-09-2003 | 03:46 PM
wwwTOPDJcom's Avatar
I dont see how you can really LEAN in on it????
wwwTOPDJcom is offline
Old 01-09-2003 | 03:51 PM
Wardey's Avatar
Wow !!!! But I doubt it will ever reach production. 4 wheels needed in the rear to handle 500 HP ? I know of bikes with over triple that HP that are running on 1. Still a bad machine. I'd love to take it for a spin......Do you have to wear a Luke Skywalker Uniform to ride it ?Wardey
Wardey is offline
Old 01-09-2003 | 03:56 PM
Sydwayz's Avatar
Forum Regulator
With each wheel having independent suspension, the bike probably leans with all four tires still on the ground.
Sydwayz is offline
