Oil temp thermostats
in reading up on oil temp thermostats, I really like the Keith Eickert oil filter/ thermostat. This would eliminate the big mess in the bilge every time I change the oil. ( stock Merc HP = sideways mount filter
Who elso make a good oil thermostat?????
Kurt.
)Who elso make a good oil thermostat?????
Kurt.
I am running the perma-cool oil stat from summit or jegs for around $35. It s a simple device. I was impressed with it. My oil temps warmed up alot quicker and the normal temp when running were around 200-210 degrees
Travis
Travis
Hello Guys,
I have used the Eickert piece in several versions with great success. A bit pricey, though. The piece Travis mentioned will generally do the job on anything not requiring a LOT of oil flow and you can get an oil filter bracket from several sources-check with your local round-tracker or you might try Canton oil filters.
They are relatively small and not too hard to change and not make a mess. Please do run a thermostat!!! Many options are available. Eickert is the most trick and the prettiest, in my opinion.
pm if I can help.
pm if I can help.
I third the Perma-cool. Yes that is the one. With my orginal oil cooler & no therm. oil pressure would start out at 80+cold & drop down to about 35 after a hard run. Now since I put a hoss of a oil cooler in with the perma cool oil pressure is still 80+cold & lowest I have seen it is 65. Oil therm also helps the oil warm up quicker.
I just bought the KE oil coolers. My research found the Permacools are only 190 degree while the KE are 210. Higher oil temp is a must with the cold water flowing through my boat motors (no water thermosat). The KE's are bigger and should flow more also. Price was much higher for the KE. The old saying "you get what you pay for".
