exhaust elbow/prevent reversion >
Old 01-10-2003 | 02:28 PM
Default exhaust elbow/prevent reversion
stock carb hp500, gil, where does the water mix with the exhaust gas on the riser? at the fitting or is the riser/elbow double-walled and enter right before the tail pipe, would I help prevent reversion and possibly increase power if I had the water mix as far back as possible-such as at my Teague switchables, does anyone make this?
Would using a dry exhaust with mufflers and dumping the water on the drives and eliminating the drive shower pickup, add speed or is it not worth the $$ and effort?
jeffg is offline
Old 01-10-2003 | 02:40 PM
The water already dumps about 2" before the end of the tailpipe. I don't think you would see any increase in performance by running dry. Just a LOT louder.
Griff is offline
Old 01-11-2003 | 09:29 PM
blown1500
You can get riser elbows that are a smooth bend, not a U-bend. This will help power noticably and will not hurt or help reversion.
Griff is correct.
articfriends
9
06-25-2005 06:38 AM
BOATING ON A BUDGET
17
02-15-2005 01:09 PM
Shah Mat
9
04-21-2004 01:37 PM
traviss
3
05-26-2002 12:17 PM
Miguel
5
04-12-2002 08:56 PM
