A Blower for CounterRotation Eng.? >
Old 01-11-2003 | 01:55 PM
KNOT-RIGHT's Avatar
Default A Blower for CounterRotation Eng.?
Anyone know what manufactuer of Blowers makes A blower or Centrifical Supercharger for a Counter Rotating Engine??????
Please Reply
KNOT-RIGHT is offline
Old 01-11-2003 | 09:38 PM
paradigm shift's Avatar
I am not much on centrifical superchargers but I am sure procharger or paxton could tell you if you called them. I run a littlefield roots blower and although I have never tried it I would think you could swap the rotors and rotate drive housing to drive off the other side thus reversing rotation. Call Marv at The Blower Shop or Mooneyham or Littlefield blowers I am sure they can tell you exactly what is involved and cost to change. I don't see why it couldn't be done.
paradigm shift is offline
Old 01-11-2003 | 10:39 PM
mcollinstn's Avatar
yeah, you should be able to swap the drive to the other side of a roots blower. The GM blowers have a drive snout that bolts to the rotor gear and you could just keep the same rotors in the case just like they are. Some of the aftermarket blowers have a physically lonnger shaft on the driven rotor - those will need swapped in the blower case and the drive shout housing flipped over.
Vortec, I believe, makes a reverse rotation impeller for some of their centrifugal pumps - other mfrs might as well - worth a call to them.
mcollinstn is offline
RMPRam
Wanted
5
09-23-2008 08:33 AM
dmaxx3500
Do It Yourself, Boating on a Budget
4
07-09-2008 06:40 AM
dmaxx3500
11
03-14-2008 09:11 AM
LapseofReason
12-15-2004 09:00 PM
fmi
08-11-2003 09:48 AM
