2500 Avalanche Towing
I currently tow a 35' Fountain on a triple axle steel trailer with a 97' F-350 dually Power Stroke Diesel extended cab. I am thinking of getting a 2500 Avalanche with 8.1 liter gas engine with heavy duty transmission. The truck is used just for towing boat. I trailer appr. 5,000 miles a summer. The 35' Fountain and trailer weigh appr. 10,000 lbs. I would like to use the new truck a little outside of trailering. The dually is a bit of a pain in ass to park in parking space. I also have Lincoln LS that I will continue to drive day to day. Keep the dually vs. update to 03' Avalanche.
I have the 2500 AV, 2002, and I love it. I have only towed 7000lbs, but I can tell you it does it very well. Others tow lots more with their 2500 AVs and Suburbans (same exact running gear). I have also upgraded with wheels, tires, K&N FIPK, true dual fllowmaster exhaust in all polished SS, airbags, and a host of other goodies.
Is your dually in bad shape? Or is it just outdated? I have to admit, if you already have a diesel dually, that has no issues, I would keep it until you are done with it. I bet it is paid for, and being a diesel, you are going to get much better mileage with it than the 8.1L. I get about 11-13 daily driving, and towing is less than 9. Honest, keep the diesel dually for a while.
I never heard of anyone going from a diesel to a gas. I have a 33 Baja Outlaw with 3 axle steel trailer which i believe is the same weight as you or a little more. I pull with a 99 F250 Crew Cab PS Diesel which pulls and stops great but over 70 mph in corners it starts swaying. I know a dually would stop the problem but I am going to try an air ride system first. My gross weight of truck, trailer, boat and all is 19750lbs with boat half full of fuel. I am sure that is probably more than the mfg recommends to pull on a single axle rear. Drive over a scales at a truck stop or grain elevator sometime i bet you will be surprised how much you weigh. Everybody should know how much they are pulling. I saw a 42' Fountain being pulled last summer by the factory bumper of a .5 ton dodge last summer.
The Avalanche can pull 12,500 no sweat. It also is not bad around town. A lot easier to deal with than a dually.
If you only pull about 5000 miles at 8 mpg vs 15 on the diesel the difference is about 300 gallons fuel or $ 450 a year. You will pay 3500 alone for a diesel over the gas engine. 7 year payoff.
Wannabe
Wannabe
ShootinTheBreeze
5
03-30-2006 05:05 PM
bn
59
09-30-2005 08:57 AM
Sydwayz
03-14-2002 10:08 AM
