30 ft. IMP eleganza...need info
i've heard engine work can be a ***** if they haev to removed. They use a wierd biult in offshore mount that a real ***** to work with. They can and do rust out and then need to be cut out or soemthing. I was considering one as aproject a while back and when i said it needed engines i was told it couls be a REAL mess.
Otehr than that i havn't heard anything else bad about them. Other than the name "IMP".
If you get it enjoy it and it coudl be nice just expect to get jokes about cruising an "IMP" from you buddies
I know of a 26' (i think) that needs engines and drive but you could pick it up CHEAP!!!!
Pardon me, while I whip this out!
Damn an OSO member only a few Miles away HOW ya doing
Im really in Vestal, Binghamton just shows on the map
I look at a IMP before to but it was too ruff for me.
Make sure ya get someone to look at any boat you buy.
E-mail Dan Angstadt at [email protected]. Located in Las Vegas, Dan is one of the original IMP dealers and knows these boat as well as anyone outside the factory. Dale
I run a 255 eleganza on Lake Erie and it rides great. I think that they have a solid fiberglass bottom which makes them a little heavy. Can't say how the longer imps ride but mine is very solid. My boat is very dry riding. The bow has wide flares up the side. Much drier then my friends Checkmate. I've heard of the weird offshore mounts but that may have been used in earlier years than my boat (1989). I have standard mercrusier mounts. I have never been able to figure out what an Eleganza is though. They are made in Iola, Kansas. Website is impboat.com I believe
My first boat was a 31 Elaganza. I used it on LOTO. I found myself out of the water more than I was in it. I rode mine really hard so alot of things started breaking in the cuddy and such.
IMP........It Might Plane. thats what I heard.
A bit heavier, but the dependability was unbelievable. Almost 600 hrs. and never skipped a beat. I've had more problems with my Scarab in only a couple months than an entire year with the IMP!
Good luck they are good boats.
Again , thanks for the advice, i think it helped...Hey brian, was kinda suprised my self, where do you boat? cayuga? i'm trying to decide between new and used...still have some time before the end of the ice age.. winter sucks.. take it easy BBR out
