BBC Compression test >
Old 01-14-2003 | 12:31 PM
Allan4
Default BBC Compression test
Am I correct is saying that the tolerence range for a BBC (454) compression test is between about 145-165psi?? I need to check the compression on two motors tonight. Also, should I go off the first reading (first engine crank) or wait till pressure builds?? I've heard both ways, not sure which to go by. Thanks, Allan
Old 01-14-2003 | 12:56 PM
I've always done it:
Warm engine
Ignition disconnected
Choke + throttle open
Charged battery
Crank til it's stable on the guage
Gary
Gary Anderson is offline
Old 01-14-2003 | 01:04 PM
Allan4
Okay cool, I am right on the psi's?? Thanks
Old 01-14-2003 | 01:09 PM
Actual psi may vary depending on cam, valves, exhaust, etc. But yeah, that's about right. Just be sure the readings are within a 5-10% range (Hi vs. low cylinder reading).
Gary
Old 01-14-2003 | 01:13 PM
Allan4
That's what I thought, thanks man, much obliged........Allan
Old 01-14-2003 | 07:34 PM
Vinny P's Avatar
I hate the winter!!
If you are doing a compression test, you have to be aware of the first hit of compression. Watch the guage, you don't want that first hit to be too low. If it is low and builds up while cranking, it probably means that there is leakage in that cylinder. This is why I prefer a leak down guage. It takes all the guess work and wondering out of the equation.
Vinny P is offline
Old 01-14-2003 | 07:38 PM
GO4BROKE's Avatar
Use both. The first jump is a good indicator of ring condition. I usually crank 6 revs each cylinder. Just do them all the same, its the comparison between cylinders you will pay most attention to.
[img][/img]
GO4BROKE is offline
Old 01-14-2003 | 11:41 PM
Allan4
Thanks for the info guys, we postponed the test, may try in a few days. Thanks again, Allan.
mausc
9
03-13-2008 11:54 PM
mausc
General Racing Discussion
1
03-13-2008 06:39 AM
ROB FREEMAN
6
10-07-2007 09:15 AM
articfriends
17
04-28-2007 12:31 AM
batty
13
03-11-2005 07:12 AM
