Having problems with Silent Choice, help! >
Old 01-16-2003 | 01:14 PM
Designie
Question Having problems with Silent Choice, help!
I have a 32' Sunsation Dominator and I had a problem before last summer with my silent choice not working. I got a wiring diagram from Corsa, and re-traced the wires and replaced all the solenoids with Bosch. It worked great, for a while. By the end of the summer, one of the two had quit and not long after that, they both quit. It just seemed to slowly get worse as the summer went on. Strange for electrical I thought. I checked the in-line fuses, they are fine.
Does anyone have any ideas? Could the relays be bad already or could the actuators be a problem?
Thanks!
Old 01-16-2003 | 01:57 PM
29Fever
I chased something similar last summer. Does it happen on both sides? Mine turned out to be misaligned by a **** hair. After 2 months of chasing electric and buying new solenoids, which you can't return, was fixed after a half turn with a screw driver. Mine would flip into the closed position just fine then fall back open right away.
Old 01-16-2003 | 02:47 PM
Kanookstr's Avatar
32' SUNSATION
Mine did the same thing. If there not aligned perfect, they are forced closed at high rpms thus burning the selenoid.
I had them switched around so when there off, thats when it's open (loud). I figuered that I only use them when I want it quiet, and thats at lower rpms. At higher rpms the selenoid is relaxed and the exhaust is open. So theres no strain on the selenoid. I havn't had any more problems sense. I'm not sure, but I think I paid around $50 - $75 each to have them reversed at Corsa.
Good luck
Kanookstr is offline
Old 01-17-2003 | 01:15 PM
wwwTOPDJcom's Avatar
I have the reverse one too ,I think its a much better idea to have
them that way, so if a seleniod takes a crap you dont haver to coathanger em open
wwwTOPDJcom is offline
35 White Lightning
Fountain
3
11-11-2006 11:34 AM
fendari
Scarab
5
09-16-2003 11:01 AM
Steve_H
23
06-05-2003 04:32 PM
dowhat
4
11-12-2002 07:14 AM
edb07
3
07-22-2002 01:03 PM
