OT: Work. Comp. woes........ >
Old 01-16-2003 | 02:13 PM
Risk Taker's Avatar
Talking OT: Work. Comp. woes........
This is a bricklayer's accident report, which was printed in the newsletter of the Australian equivalent of the Workers' Compensation Board. This is a true story. Had this guy died, he'd have received a Darwin Award for sure..
Dear Sir,
I am writing in response to your request for additional information in Block 3 of the accident report form. I put "poor planning" as the cause of my accident. You asked for a fuller explanation and I trust the following details will be sufficient.
I am a bricklayer by trade. On the day of the accident, I was working alone on the roof of a new six-story building. When I completed my work, I found that I had some bricks left over which, when weighed later were found to be slightly in excess of 500lbs.
Rather than carry the bricks down by hand, I decided to lower them in a barrel by using a pulley, which was attached to the side of the building on the sixth floor.
Securing the rope at ground level I went up onto the roof, swung the barrel out and loaded the bricks into it. Then I went down and untied the rope, holding it tightly to ensure a slow descent of the bricks.
You will note in Block 11 of the accident report form that I weigh 135 lbs.
Due to my surprise at being jerked off the ground so suddenly, I lost my presence of mind and forgot to let go of the rope. Needless to say, I proceeded at a rapid rate up the side of the building.
In the vicinity of the third floor, I met the barrel, which was now proceeding downward at an equally impressive speed.
This explained the fractured skull, minor abrasions and the broken collar bone, as listed in section 3 of the accident report form.
Slowed only slightly, I continued my rapid ascent, not stopping until the fingers of my right hand were two knuckles deep into the pulley.
Fortunately by this time I had regained my presence of mind and was able to hold tightly to the rope, in spite of beginning to experience pain.
At approximately the same time, however, the barrel of bricks hit the ground and the bottom fell out of the barrel. Now devoid of the weight of the bricks, that barrel weighed approximately 50 lbs.
I refer you again to my weight, 135 lbs.
As you can imagine, I began a rapid descent down the side of the building. In the vicinity of the third floor, I met the barrel coming up.
This accounts for the two fractured ankles, broken tooth and several lacerations of my legs and lower body.
Here my luck began to change slightly. The encounter with the barrel seemed to slow me enough to lessen my injuries when I fell into the pile of bricks and fortunately only three vertebrae were cracked.
I am sorry to report, however, as I lay there on the pile of bricks in pain and unable to move, I again lost my composure and presence of mind and let go of the rope and I lay there watching the empty barrel begin its journey back down onto me.
This explains the two broken legs.
I hope this answers your inquiry.
Sid
Risk Taker is offline
Old 01-16-2003 | 02:53 PM
seanclong's Avatar
Killing me!!!!!!!!!!!! LOL
seanclong is offline
Old 01-16-2003 | 03:08 PM
OldSchool's Avatar
He had a bad day
OldSchool is offline
Old 01-16-2003 | 03:19 PM
Hauling Trash's Avatar
WOW I love it
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Hauling Trash is offline
Old 01-16-2003 | 03:29 PM
ChrisK's Avatar
Moderator
And I thought I was having a bad day... HA! not any more!
ChrisK is offline
Old 01-16-2003 | 03:41 PM
Mark in So. MD's Avatar
Dammmmm!!!!!!!
Mark in So. MD is offline
Old 01-16-2003 | 03:46 PM
Payton's Avatar
Charter Member #927
Old one but a good one.
Payton is offline
Old 01-16-2003 | 03:58 PM
Steve 1's Avatar
Steve 1 is offline
Old 01-16-2003 | 04:53 PM
CigDaze's Avatar
LMFAO every time I read it!
I only wish it was on video!
CigDaze is offline
Old 01-16-2003 | 06:49 PM
gdfatha's Avatar
My EX got the Sleekcraft
Thanks for sharing..
gdfatha is offline
