Free gift
Old 01-17-2003 | 10:53 AM
mopower's Avatar
Toxic FORMULA
Default Free gift
Well after upping my membership to Gold and scanning through the uncensored section , I now have porn pop ups when ever I turn on my computer
Cleared history and temp internet files...no help.
Any other ideas from you computer garus out there
mopower is offline
Old 01-17-2003 | 11:09 AM
florida gator's Avatar
I haven't had that problem.
florida gator is offline
Old 01-17-2003 | 11:17 AM
CigDaze's Avatar
No problem here or at home...
Download a progmam called "Ad-aware"
It helps get rid of the nested codes on your machine which leads to pop-ups.
CigDaze is offline
CigDaze's Avatar
Here it is:
http://www.lavasoftusa.com/
CigDaze is offline
Old 01-17-2003 | 12:54 PM
Wardey's Avatar
No probs here, but I don't visit that section either...... I use Pop Up Stopper and it works for me. Wardey
Wardey is offline
Old 01-17-2003 | 02:11 PM
CHAOS REIGNS's Avatar
spybot seems to be the best out there
it will find stuff you NEVER knew was on your computer (stuff installed by other programs that you actually wanted to run)
get the one with the installer
http://www.net-integration.net/spybot/spybotsd.html
CHAOS REIGNS is offline
Old 01-17-2003 | 06:19 PM
cgarrett's Avatar
I also have what BajaDaze posted and have no problems.
What were you looking at
Cordell
cgarrett is offline
Old 01-17-2003 | 07:42 PM
Clay Washington's Avatar
Default Startup List
If you are using MS Windows...
Click on Start and then Run.
Type in: MSCONFIG
Click on the Startup tab.
Go to the bottom and look for anything suspicious.
Uncheck the box of the suspicious program and click OK.
Reboot your computer and see if you still get the Popups.
Warning - I am not responsible if you crash your system. I am only trying to help!
Clay Washington is offline
Old 01-17-2003 | 10:04 PM
SeaRay Jim's Avatar
Default Re: Startup List
Originally posted by Clay Washington
Warning - I am not responsible if you crash your system. I am only trying to help! [/B]
Hell Clay, you just want the pop ups!
SeaRay Jim is offline
Old 01-17-2003 | 10:24 PM
mopower's Avatar
Toxic FORMULA
Clay,
Sounds good I'll give it a try. It shows up in the address block up to as arnachyporn.com
It seems to have something to do with start up , since once its up and appears and I delete it its usually gone , only to reappear after start up again
I suspect I got it off of another link I clicked on , on uncensored
Cal (mopower)
mopower is offline
DannyD
New Products and Member Discounts
2
12-21-2004 06:23 PM
DannyD
12-15-2004 11:11 PM
DannyD
General Racing Discussion
3
12-12-2004 08:56 PM
