What Ratio with XZ Upper and Sportmaster Lower >
Old 01-19-2003 | 03:52 PM
Sonny Spectre 30's Avatar
Default What Ratio with XZ Upper and Sportmaster Lower
would you get ?
I have XZ uppers with 1.36 Gears and want to try the new shorter sportmaster lowers. What ratio would I get with an out of the box bolt up?
Sonny Spectre 30 is offline
Old 01-19-2003 | 04:09 PM
Mbam's Avatar
Offshoreonly Advertiser
Depends which of the sportmasters you use, they are avaiable in 15/19, 15/17 and 17/18 ratios. The overall ratio of your XZ (or any drive for that matter) is the upper ratio x the lower ratio.
A 1.36 drive = 29/27 (upper) x 19/15 (lower), so the possible ratios with your upper are 1.36, 1.217 and 1.137
Just like life, no single simple answer
Mbam is offline
Old 01-19-2003 | 04:15 PM
Thanks for the help.
Is 19/15 stated correctly here as it differs from the way you stated above? What would the poss. ratio's be with 1.5 uppers?
Thanks.
Sonny
Old 01-19-2003 | 04:27 PM
Mbam's Avatar
Oops,
Yes I reversed the numbers in the lower for the math to work the way I showed. It should have been 19/15, 17/15 and 18/17 in this case as both the upper and lower are reductions.
A 1.5 XZ has a 32/27 upper , possible ratios are 1.5, 1.343 & 1.254
Don't forget that there is also a 30/23 upper, the resulting 1.65 ratio can be worth a few MPH on some boats but it puts a greater torque load on the lower unit
Mbam is offline
Old 01-19-2003 | 04:46 PM
Thanks again. This will help me with my project.
Old 01-19-2003 | 05:01 PM
SpectreBoy's Avatar
Default Oh, yea
Sonny, just sell that boat, get one with outboards, then you can run with me next summer.............LOL, what are you up too anyway, blowers?
SpectreBoy is offline
Old 01-19-2003 | 05:05 PM
Byron
Ask powerboat service , I'm sure they know!
Old 01-19-2003 | 05:37 PM
Mark,
If I remember correctly I was in frony of your the WHOOOOL time at lake Cumberland!
Fixin to go to Florida where it's warm for some testing.
Lyron,
When are you going to quit whining and step and get that new 36
Spectre?
Old 01-19-2003 | 05:47 PM
Byron
You gotta love OSO! SEE YA!
Sonny, you just have to keep the good deals coming so I can afford the 36'
awsomethunder
Drives and Lower Units
5
08-27-2008 08:47 PM
axapowell
Wanted
3
04-16-2008 06:34 PM
Smarty
13
06-17-2007 11:08 AM
FormulaM2Formula
6
06-06-2006 09:23 PM
Tantrum
06-17-2005 09:42 AM
