chips in gelcoat on bottom strakes >
Old 01-19-2003 | 09:46 PM
26sonic's Avatar
Default chips in gelcoat on bottom strakes
i have a few chips on the bottom of my boat on the strakes will this cause my boat to loose any mph or will it not effect it that much?
26sonic is offline
Old 01-19-2003 | 10:32 PM
Audiofn's Avatar
Charter Member #232
Should not effect it that much, however fiberglass is poroise and will obsorbe water. Don't freek about it but I would try and get it repaired at some time
Jon
Put your best foot forward!
Audiofn is offline
Old 01-20-2003 | 08:48 AM
I have numerous chips on my 1990 30SS. I don't know why you would have them but mine were caused by air pockets between the gelcoat and fiberglass. You should fix them asap. Water will work it's way under the gelcoat and when it freezes will continue to loosen into a larger area. I doubt you will loose any speed or handling.
Pure Energy is offline
Old 01-20-2003 | 10:22 AM
LIOPA's Avatar
Repair - ASAP
The chips tend to spread over time making the affected area grow in size. Faster even in very frigid regions like mentioned above. Water gets in and freezes creating a larger damage area.
LIOPA is offline
taxguy
Detailing, Painting, & Fiberglass
5
09-06-2006 03:06 PM
Cattitude
3
07-29-2006 08:23 AM
IHTFP
7
04-18-2006 09:47 PM
gsmith9898
3
07-07-2005 06:18 PM
epeek
8
05-31-2003 12:35 AM
