After market sub's for Merc Trim & Planes pump Solenoids >
Old 01-21-2003 | 01:15 PM
blown formula's Avatar
Question After market sub's for Merc Trim & Planes pump Solenoids
Another stupid question:
Is there an after market supplier for solenoids as used for the trim & planes pumps? It seems an automotive solenoid would do the same thing, but Merc units are HI $$$ stuff.... any ideas????
blown formula is offline
Old 01-21-2003 | 02:50 PM
Iggy's Avatar
Look into Sierra Marine Parts. A lot of the on-line sites sell this brand.
They manufacture/sell Mercury equivalant parts at a much lower price.
My trim pump solenoids are p/n 18-5817 from Sierra.
I did a quick search on the p/n and found them for 13.67 each.
Is that low enough?
Iggy is offline
Old 01-21-2003 | 04:05 PM
mcollinstn's Avatar
I ran lawnmower solenoids on an old outboard tunnelvee I had. $6 each. All brass and plastic (with zinc plated mount). I covered the connections with liquid tape and never had any troubles at all.
Even sunk it once (freshwater) and the solenoids still worked fine.
Why the Mercs are big $$$ - who knows, greedy I reckon.
mcollinstn is offline
Old 01-21-2003 | 04:34 PM
mopower's Avatar
Toxic FORMULA
A friend of mine has used Ford starter solenoids for years. Fresh water environment they work fine. I don't know if I'd use them around saltwater though. He did change the nuts to stainless from the original "plated" nuts.
mopower is offline
Old 01-21-2003 | 05:56 PM
formula31's Avatar
Yea, Ive used the Ford started solenoids too. They were less than $10 at Napa and completely sealed.
formula31 is offline
Old 01-21-2003 | 10:54 PM
You can buy marine solenoids from NAPA they have a marine catolog. same as serria
mmwalters is offline
Old 01-22-2003 | 09:21 AM
That's sort of what I thought. There is a rubber gasket on the Merc units, but they are by no means water tight. I thought the Ford solenoid's were a kind of "multi-purpose" solenoid for everybody!.
Mc Collistin- what lawn mower relays??? Manuf/brand/part #???
Thanks guys, guess I'm just cheap!!
Old 01-22-2003 | 06:45 PM
wwwTOPDJcom's Avatar
I rebuilt mine by opening the case and filing the contacts
then sealed with liquid electrical tape, I did this on the water
had no choice and I have not had to replace it.
wwwTOPDJcom is offline
Old 01-22-2003 | 09:42 PM
Ok, I went to my O'reilly's auto parts store this evening...... I asked what do you have in a SMALL solenoid/relay, he goes to the rack in the middle of the store & shows me a packaged solenoid/general purpose for $7.00 !!! It looks exactly like the Mercruiser unit except better! The case is riveted not crimped. A heavy rubber & cork gasket in place of a tiny thin membrane like Merc's unit.... and a single operating/actuating contact. I bought 8 for less than what two Merc's cost.....going to try them this weekend!!
NJThumper
05-11-2022 06:32 PM
NJThumper
3
05-24-2007 07:30 AM
ratman
01-26-2006 07:48 PM
GregP
9
08-08-2005 03:51 PM
CelticPride
3
07-03-2002 12:15 PM
