Repowering 33 Outlaw >
Old 01-23-2003 | 06:24 PM
outlawinil's Avatar
Default Repowering 33 Outlaw
I am repowering my 33 outlaw and have sold my 7.4L MPI's. Will 500HP's use the same motor mounts as the 7.4's and if so are they heavy enough to handle the extra torque? Would you guys spend $3500/ engine more for 500HP's over 502 MPI's?
outlawinil is offline
Old 01-23-2003 | 07:47 PM
liquid asset's Avatar
The mounts are fine. IMHO spend the extra dough if they are efi's, don't if their carbs. How fast, or slow was it with 7.4's
liquid asset is offline
Old 01-23-2003 | 07:51 PM
Big E
502's are nice but 500hp's are more nice. You will probably have a higher resale value if you go to the 500hp's. This may be an isolated case because I only have one friend who has 500 hp's in his boat, (all of my other friends have 502 mags or 454's) but his 500 hp's are high maintenance, I personally think the 502's are indestructable as far as reliability, just my opinion, but that doesn't mean much. I'm sure there are many other people out there that have 500 hp's and they are reliable for them. My buddy with the 500 hp's runs his boat pretty hard. All I know is that he is constantly working on them. Maybe this will help. I can say when his boat is running it is a rocket. Also if you are going to go with the 500 hp's I would invest in offshore motor mounts if you don't already have them. Thanks - Eric
Old 01-23-2003 | 08:09 PM
The 500 Efi's are no more maint. than a 502, the carb motors need a valve spring and exhaust change to cmi's instead of gill's
Old 01-23-2003 | 08:56 PM
HP 500s high maintenance????????????????
Twin 1999 HP 500s carbed, approaching 300hrs. Oil - filters - 1 set of spark plugs that they did not really need.
What more can you ask for?
Mark
GETTINBYE is online now
Old 01-23-2003 | 09:03 PM
outlawinil's Avatar
Liquid asset- top speed was 59.8 @ 4400 rpm. I bought the boat new very reasonalbe with the intention of repowering if I didn't like the speed. It was going to be another $32000 retail to upgrade to 502 EFI's.
BigE- You bring up a good point that I always look at when buying a boat or vehicle, resale value. I have heard people say at 200 hour to check the top end of the 500HP's just for routine maintainence
What do you guys think would be the most dependable and reliable of the two?
Old 01-23-2003 | 09:05 PM
outlawinil's Avatar
Gettin Bye- hey thats great. What are they in? Speed? Props?
Old 01-23-2003 | 09:23 PM
Big E
I have heard the same thing after 200 hours, there you go, I haven't heard about that for the 502 EFI's. I had a single 454 Carbed, and it was a cold natured motor but a good one. It was tougher to start (pumping the throttle only when the motor was cold and sat for a day or two) and I had to let is warm up to operating temp before pushing down the throttle, otherwise the boat would stall below 170 degree operating temp. I have sold that boat, and bought a 1999 with a single 502 EFI, what a difference, the boat fires right up and you can throttle up before operating temp. I really like the fuel injection. Just my opinion, See I told you someone would get upset about my comment on the 500 hp's. I still like them but my preference is the 502 EFI. Eric
Old 01-24-2003 | 06:45 AM
bajadude's Avatar
I'm with GETTIN' BYE
HP500s
Got carbed ones in my ' 99 33, 165 hours no problems. Plus they look really cool
bajadude is offline
Old 01-24-2003 | 06:46 AM
outlawinil,
1999 36 Outlaw, Labbed 25 Mirage +, Low to mid 70s depending on weather, water, load, etc.
Going to try some Bravo 1s this year.
Mark
