*OT: Words Of Wisdom
The Senior Charter Member #1070
Do not walk behind me, for I may not lead, do not walk ahead of me, for
I may not follow, do not walk beside me either, just leave me the hell
alone.
The journey of a thousand miles begins with a broken fan belt and a
leaky tire.
It's always darkest before dawn. So if you're going to steal the
neighbor's newspaper, that's the time to do it.
It's a small world. So you gotta use your elbows a lot.
We are born naked, wet, and hungry. Then things get worse.
No one is listening until you make a mistake.
Always remember you're unique, just like everyone else.
Never test the depth of the water with both feet.
It may be that your sole purpose in life is simply to serve as a warning
to others.
It is far more impressive when others discover your good qualities
without your help.
If you think nobody cares if you're alive, try missing a couple of car
payments.
If you tell the truth you don't have to remember anything.
If you lend someone $20, and never see that person again; it was
probably worth it.
If you haven't much education you must use your brain.
You can't strengthen the weak by weakening the strong.
Who gossips to you will gossip of you.
When someone says, "Do you want my opinion?" - it's always a negative
one.
When someone is having a bad day, be silent, sit close by and nuzzle
them gently.
The word listen contains the same letters as the word silent.
The trouble with work is - it's so daily.
The difference between ordinary and extraordinary is that little extra.
Scientists say 1 out of every 4 people are crazy. Check 3 friends, if
they are OK, you're it.
Pain and suffering is inevitable but misery is optional.
alone.
leaky tire.
to others.
without your help.
payments.
probably worth it.
one.
them gently.
(What you see, is what you get!)
"Live every day to it's fullest for you give a day of your life to it."
