Merlin II vs Merlin II race, and Merlin Pro Blocks >
Old 02-06-2003 | 09:35 AM
Ratchet's Avatar
Question Merlin II vs Merlin II race, and Merlin Pro Blocks
Ok guys, here's one. Had a discussion the other day with a friend, who has built some killer engines for cars & boats. In any case, we got into a debate in regards to "cast main caps vs billet caps."
My take - Nodular main caps should be fine (maybe I'd consider studs, since they are not splayed) in most naturally aspirated motors, such as the standard Merlin II block. I would tend to think the split to consider billet caps would most likey be 950-1000 hp mark.
His take - You NEED the splayed billet caps for anything that makes any power (whatever "any" means, especially if he isn't funding it).
Anyways, I typically don't hear of N/A engines failing from a main cap "giving." So, I'd like to ask, what are your thoughts on the cast vs. billet caps ? Here's a link to some of the different block info.
http://www.worldcastings.com/downloa....shtml#bbchevy
Thanks !
Ratchet is offline
Old 02-06-2003 | 11:22 AM
Dowel tubes around main studs/bolt holes will also keep the caps from moving. After this is done the motor needs to be align bored. I know of a few 900 HP 8500 RPM drag motors running 2 bolt doweled mains with no trouble. Good main studs of course!! The purpose of the splayed caps is to keep the mains still. I think some splayed cap motors are still doweled for added security. I heard there is now a Merlin III. Anyone know about this block?
WETTE VETTE is offline
Old 02-06-2003 | 11:36 AM
dyno's Avatar
Charter Member #655
Rachet I'm with you I think its over kill.....I'm a pump gas guy so under 600 hp its way over kill!!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 02-06-2003 | 12:01 PM
Ratchet's Avatar
Heck.........I'm not going to be building anything for a while, but I got into the boat I've always really liked, but I needed to find power for it (31 scarab), and I'm running 425 plus Hp @ 6000 through 2 bolt small blocks with studs, pushing this tank to 70, and the engines previously had almost 400 hours on them. So I think that the block would be plenty strong at say 7-800 or so. Bill Mitchell even uses them on his 632 CI engines (not sure if they have the billet caps or not).
Wette Vette - On the Spec sheet, it indicates that they are dowelled..good point though. I haven't heard anything about the merlin III. Could this maybe be the merlin II race block (billet steel mains) ?
Ratchet is offline
Old 02-06-2003 | 12:04 PM
Ratchet's Avatar
I actually used the engines out of my old boat for this.
Ratchet is offline
Old 02-06-2003 | 04:32 PM
jdnca1's Avatar
I don't think World is building ANY Merlin II's now, my understanding is all NEW production is the Merlin III. I was told this at the Bill Mitchell booth at the PRI show anyway....
jdnca1 is offline
Old 02-07-2003 | 07:46 AM
Ratchet's Avatar
Sounds like this could be valid...........Bill Mitchell is one of the the main ditributors for these blocks, I believe. Actually, if you call the "old" world product #, they refer you to Bill Mitchell.
Any more info on this block itself would be greatly appreciated, if anyone has any yet.
Ratchet is offline
Old 02-07-2003 | 08:10 AM
blown1500
Bill Mitchel=World Products
Strip Poker 388
9
06-14-2007 09:51 AM
f311fr1
03-13-2005 12:47 PM
f311fr1
0
03-12-2005 06:56 PM
carreraboat
5
07-15-2003 10:45 AM
SABER28
30
10-20-2002 08:17 PM
