Mercruiser killer ??????
Old 02-06-2003 | 06:52 PM
wwwTOPDJcom's Avatar
Question Mercruiser killer ??????
http://www.dbdmarine.com/gallery/index.htm#
wwwTOPDJcom is offline
Old 02-07-2003 | 09:04 AM
Scarab3DMC's Avatar
Thumbs up
Oh...... the times are a changing!!!!! now if they make an transom plate to adapt from a TRS to their unit..... we already have the tranny.......intresting.........
Scarab3DMC is offline
Old 02-07-2003 | 09:49 AM
I too saw this in this months
Popular Science Magazine.
Looks like the prop selection is
more user friendly.
The steering system looks
a little "cheezy", maybe not
up to task for hi perf. setups.
my .02
jt
JaayTeee is online now
Old 02-07-2003 | 10:02 AM
BAJA WILL's Avatar
Registered User
Help me understand. This is a direct drive?? SO how could it be used in a v hull?? Do you mount the motor at an angle and have a UV joint? Can you mount a motor low enough to hook up to it?
I like the idea, just not sure how it hooks up?
BAJA WILL is offline
Old 02-07-2003 | 10:21 AM
Interesting concept. You will need a down angle, offset tranny which has full power reverse capabilities and gear reduction though.
It looked to be different from the arneson or pulse in that it doesn't use a single shaft. The prop shaft looks to be angled upward, parallel to the bottom of the boat. I would think that this feature would allow better trim control and a shorter drive.
Gary
Gary Anderson is offline
29KILROY
Baja
20
09-09-2008 10:31 AM
pm203
Cigarette
23
11-04-2006 08:53 AM
KH0302
03-24-2004 07:34 AM
Risk Taker
09-26-2003 05:59 AM
