Bobby Daniels >
Bobby Daniels
Bobby Daniels
Old 02-11-2003 | 09:36 AM
JimV's Avatar
Default Bobby Daniels
Bobby
Can you post the airflow numbers from the AFR heads. Also can you post the diameter of the venturiis? thanks
JimV is offline
Old 02-11-2003 | 12:10 PM
bobby daniels
Sure Jim I said I would and I will When I have time to stop by the shop .
Old 02-11-2003 | 12:33 PM
JimV's Avatar
JimV is offline
Old 02-11-2003 | 01:15 PM
blown1500
JimvV,
Which AFR heads do you need numbers for? If you will let me know, I'll get the info for you
Old 02-11-2003 | 05:12 PM
JimV's Avatar
blown 1500
I'm looking for numbers on the 335 head. In different post Bobby said he got four sets in and he would post the numbers. I'm curious to see numbers on different flow benches, thanks JimV
JimV is offline
Old 02-12-2003 | 04:48 PM
blown1500
JimV, intake venturi is 2.048", exhaust is 1.675" on the AFR 335 heads. That is as close as I can measure, maybe +or- .002"
I havn't had time to put them on the flow bench yet, will try to do it Satyurday. Hope this helps!!
Old 02-17-2003 | 03:07 PM
JimV's Avatar
thanks!
JimV is offline
t town
11-08-2006 08:12 PM
Breathe Later
3
06-24-2003 01:34 PM
KAAMA
1
05-18-2003 09:37 AM
formula31
04-07-2003 10:00 PM
speedrush
10-20-2002 09:30 PM
